Driveshaft: Outboard Joint + Knuckle
Old Oct 20, 2006 | 11:28 PM
K-Spec's Avatar
Default Driveshaft: Outboard Joint + Knuckle
So I was having this problem before:
the caliper was rubbing against the rotor.
and then I removed my wheel tonight and found the two screws holding the rotor to be loose so I tightened those up, but then I saw this...and was wondering if this looks normal.
this is a pic of the outboard joint connected to the knuckle (sorry for the blurryness)
What do you guys think?
Old Oct 21, 2006 | 03:18 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: Driveshaft: Outboard Joint + Knuckle (khalal538)
That toothed ring spins past a wheel-speed sensor for your ABS or traction control system. I don't see how it could possibly affect your caliper mounting or brake rotor.
cautiousk
Suspension & Brakes
19
Dec 24, 2012 07:56 AM
K-Spec
Oct 21, 2006 10:53 PM
opiumdaze
Oct 11, 2005 09:27 PM
SIMATIC
Apr 5, 2005 04:45 AM
