Driveshaft: Outboard Joint + Knuckle
So I was having this problem before:
the caliper was rubbing against the rotor.
and then I removed my wheel tonight and found the two screws holding the rotor to be loose so I tightened those up, but then I saw this...and was wondering if this looks normal.
this is a pic of the outboard joint connected to the knuckle (sorry for the blurryness)
What do you guys think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">If the axle nut is torqued properly and staked, I wouldn't worry about it.</TD></TR></TABLE>
well, it's not staked for sure and i'm not sure if it was torqued properly. there's actually some free play between the knuckle and the axle.
so put a 32mm socket and torque wrench on there and tighten it up to 132 lb-ft. It will pull the axle into place, and then stake the nut with a screwdriver into the notch on the theaded part of the axle.
Ammadien
15
Jul 14, 2006 05:00 PM
Rocks
15
Jul 5, 2004 04:48 PM
