99 00 civic foglight wiring
Old Oct 20, 2006 | 11:01 PM
toekneexD's Avatar
Default 99 00 civic foglight wiring
whats up guys.. i just got a set of civic foglights for cheap.. oem stanley for 50 bucks.. the thing is.. i dont have a harness or switch... just the wires that come off the foglight.. soo my question is... how should i hook them up? should i just put them to my parking lights? so whenever my parking lights are on my foglights are on? or should i go buy a switch? also.. im not all that good with switches and wiring... soo how would i wire this up? ill be putting this all in tomorrow.. i need help fast.
also..should i get yellow bulbs or paint the lense yellow?
Modified by toekneexD at 12:15 AM 10/21/2006
Old Oct 21, 2006 | 12:49 AM
hatch96y7's Avatar
Default Re: 99 00 civic foglight wiring (toekneexD)
http://www.passwordjdm.com/Ins...s.pdf
Old Oct 21, 2006 | 01:25 AM
20CiViCSi00's Avatar
Default Re: 99 00 civic foglight wiring (hatch96y7)
i am gonna do a foglight re-setup as i bought my car with no foglights(but the foglight cut outswhere alredy done)i am fOr sure gonna favorite this.
Old Oct 21, 2006 | 07:02 AM
toekneexD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.passwordjdm.com/Ins...s.pdf </TD></TR></TABLE>
read the post... i have no harness.
is there a way i can just tap into my parking lights for now untill i get a harness.? would that give enough power?
Old Oct 21, 2006 | 08:16 AM
yoej8's Avatar
try contacting the dealer if you haven't already.
Old Oct 21, 2006 | 08:18 AM
92'si's Avatar
i would def buy the harness cause youll need the relay for longevity. but connected to your fog lights is the ground and the female plug right?
Old Oct 21, 2006 | 08:46 AM
hatch96y7's Avatar
yes sir
any other mind puzzling ideas
Old Oct 21, 2006 | 10:37 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:36 AM 11/16/2006
Old Oct 21, 2006 | 04:28 PM
Asimo-Tech's Avatar
bro people r gonna call u cheap... just buy the right harnes...
but if u wanna go the getto way be sure u know how to do it...
1--Get a switch and enough wire from radio shack
2--Mount the switch anywere in the dashboard
3--The ground from the fogs goes to the chasi
4--Run a wire from any 12v to the switch and from the switch to the fogs
Good luck....
Old Oct 21, 2006 | 10:02 PM
toekneexD's Avatar
Default Re: 99 00 civic foglight wiring (Asimo-Tech)
alright soo now i have the stock switch.. and the foglights... all theses parts are OEM honda.. soo how would i go about wiring this up? i have a red green. a red black. and a black i belive... which one is the constant and which one is the foglights? also.. would both foglights go to the same wire? how would this go? thanks for the input everyone
again i have no harness or relay.. just the switch and the foglights.
Old Oct 22, 2006 | 02:42 AM
White95SiHB's Avatar
You can always buy a universal foglight wiring harness kit (range from $10 on up). However, you won't be able to use the stock switch with it, unless you do some custom wiring (which is the tricky part).
Just trying to give you an idea.
tercelrcr
Aug 28, 2013 07:07 AM
PHAT-INTEGRA
Sep 11, 2007 08:08 AM
popeface
Apr 6, 2006 03:20 PM
.brian.
Dec 14, 2005 10:30 AM
