Need help with b18c5 build
Old Oct 20, 2006 | 10:21 PM
DCtooD's Avatar
Default Need help with b18c5 build
My setup consists of:
p30 pistons
jun3's
ssr header
68mm tb
Is this enough to break 200 whp? If not what else could I do?
Old Oct 22, 2006 | 03:21 PM
greeneg2.0's Avatar
Default Re: Need help with b18c5 build (DCtooD)
you should make over 200 horese
you are useing b16 pistons what head are you useing
Old Oct 22, 2006 | 10:26 PM
DCtooD's Avatar
Default Re: Need help with b18c5 build (greeneg2.0)
Stock itr which I just got back from machining. Thinking of getting IB intake manifold but don't know if it's worth putting it on a unported head.
Old Oct 23, 2006 | 03:06 AM
01-0720's Avatar
whats your comp ratio gonna be at with those p30's?
Old Oct 23, 2006 | 04:17 AM
DCtooD's Avatar
Default Re: Need help with b18c5 build (01-0720)
I'd say maybe like 11.6-11.7 with an oem 3-layer.
Old Oct 23, 2006 | 11:12 AM
01-0720's Avatar
wow i didnt think it whould be that high
reason i ask is because im building my c5, and i was debating between p30's and jdm itr pistons
Old Oct 23, 2006 | 12:06 PM
Drew17th's Avatar
im personally getting jdm itr pistons for my itr block... raise the compression somemore with my fully built head.... should be fun enuff!
Old Oct 23, 2006 | 12:12 PM
ABCVTEC's Avatar
Default Re: Need help with b18c5 build (Drew17th)
this thread makes my mouth water. i want an ITR head
why the b16 pistons though?
Old Oct 23, 2006 | 02:24 PM
DCtooD's Avatar
Default Re: Need help with b18c5 build (ABCVTEC)
using p30's to bump the comp a little and also the head was milled slightly so it could be a little higher but still under 12.
Drew17th
Oct 30, 2006 12:51 PM
92integraVTECgsr
Mar 27, 2006 08:09 AM
hott95ej2
Sep 25, 2005 10:35 AM
05 S2K Stoner
42
Dec 10, 2004 09:07 PM
:jdmshmaydm:
Jan 2, 2003 06:32 PM
