k20a2 into a del sol
Old Oct 20, 2006 | 07:59 PM
projektcivic's Avatar
Default k20a2 into a del sol
is it the same mounts/ axles as a civic?
what all is needed other than:
- Motor
- Hydraulic Tranny
- ECU (PRB)
- Axles with Half Shaft
- Shift Cables
- Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
- All Sensors Needed
if anyone can help me out with this i'd appreciate it.
Old Oct 20, 2006 | 08:01 PM
Micha's Avatar
FAILWGN
Default Re: k20a2 into a del sol (projektcivic)
Hey. Words of advice. Go to K20.org. There is a ton of stuff over there on this subject.
Old Oct 20, 2006 | 08:05 PM
Default Re: k20a2 into a del sol (Blu99teg)
thanks man. will go to it now.
Old Oct 20, 2006 | 08:07 PM
Micha's Avatar
FAILWGN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projektcivic &raquo;</TD></TR><TR><TD CLASS="quote">thanks man. will go to it now.</TD></TR></TABLE>
Cool. Hope I didn't sound rude at all.
Old Oct 20, 2006 | 08:20 PM
VinceTEC's Avatar
Definitely check out http://www.k20a.org for more information.
The swap is pretty much the same as any other 92-95 EG Civic... in fact, the shifter box sits even nicer on a Del Sol, much higher because of the high hump.
Search "Hatch2k" you should be able to see my K20 Del Sol build up!
Old Oct 24, 2006 | 06:25 AM
johnson02's Avatar
what's up Caleb, this is LaRon. You got yourself another del sol? I picked up a k20a3 block off drag for my hathc.
Old Oct 24, 2006 | 07:13 AM
6SPD_EK's Avatar
Default Re: k20a2 into a del sol (johnson02)
be prepared to drop about $8-15,000... you'll need the same mounts, axles, etc as eg/dc K swaps
there is a lot of extra **** you'll need too - i know
http://videos.streetfire.net/s...3.htm &lt;---UNEDITED in-car & outside footage before my exhaust was installed... note I barely touched 6th around 130ish
do your research (k20a.org is the place to start)... k24 block with a2 head... the a3 will need quite a bit of work to make good hp
cody_sandlin
Aug 9, 2013 05:19 AM
Vtec GSR95
Jan 27, 2009 08:16 AM
brandonejoos
Mar 14, 2007 08:15 PM
ubercerealkiller
Mar 30, 2005 03:45 AM
jbell
22
Apr 12, 2004 03:22 PM
