Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!!
Old Oct 20, 2006 | 06:02 PM
MrHeeltoe's Avatar
Default BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!!
Check the date! Heeltoe is your OG Beaks Dealer! I installed the first prototype SRK-DC on ShanKs car something like 8 years ago!!!
Use convenient online ordering on Heeltoe Automotive's state of the art shopping cart!
www.heeltoeauto.com
SRK - SUBFRAME REINFORCEMENT KIT
EG/DC
EK
Initially designed for use with the DC-Integra Type-R 22mm rear anti-sway bar, the SRK is proven effective in safeguarding the vehicle's subframe structure. Due to thin construction of the sheet metal, mounting hardware often shear off and destroy the swaybar mounting points, resulting in expensive repairs. The SRK provides reinforcement from both the front and the backside of the mounting points. Loads are distributed over a large area, which helps reduce the stress and effectively prevents sheet metal failure.
COMPATIBLE WITH ALL SWAY BARS, OEM OR AFTERMARKET
Heeltoe Automotive offers sway bars in a variety of diameters!
ITR 22 and 23 mm
CTR 22 mm
Cusco EK 18 and 24 mm
Cusco EG/DC 25mm
Mugen EK 18, 20 and 24 mm
CONTACT US TODAY FOR Quick Swap kits which include EVERYTHING you need to install a sway bar on your EG, EK, and DC!
_____________________________________
Beaks also offers an effective lower subframe brace that is compatable with the Beaks SRKs!
SUBFRAME TIE-BAR
Most aftermarket lower tie-bars use a rod-end bearing type connection for proper fitment. This however allows the subframe to flex under load and minimizes its effectiveness. The Beaks subframe tie-bar design has no pivot points. Its square tube configuration provides excellent rigidity and lightweight. Additionally, the STB is 100% compatible with the SRK-EG/DC subframe reinforcement kit.
AND IT LOOKS AWESOME! Contact Heeltoe for combo deals!!!!!
www.heeltoeauto.com
Modified by MrHeeltoe at 7:26 PM 10/20/2006
Modified by MrHeeltoe at 4:30 PM 1/30/2007
Modified by MrHeeltoe at 7:29 AM 12/12/2007
Old Oct 22, 2006 | 07:35 PM
EJ1_203's Avatar
Default Re: BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!! (MrHeeltoe)
how much for the sube frame kit and the bar? for an eg coupe
Old Oct 23, 2006 | 06:58 AM
hondaman86's Avatar
how much for subframe brace on a ek hatch?
Old Oct 23, 2006 | 12:57 PM
MrHeeltoe's Avatar
replied, thanks for the posts!
Old Oct 23, 2006 | 02:43 PM
AlwayzSpoolin's Avatar
Default Re: (MrHeeltoe)
DO you offer the Beaks kit plus the sway bar combo ?If so how much
Old Oct 24, 2006 | 10:01 AM
MrHeeltoe's Avatar
Default Re: (AlwayzSpoolin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlwayzSpoolin &raquo;</TD></TR><TR><TD CLASS="quote">DO you offer the Beaks kit plus the sway bar combo ?If so how much </TD></TR></TABLE>
Actually yes we do. We have 18, 22, and adjustable 24mm for EK, and 22, 23, 25mm for EG/DC!
Check out the Tealtoe project for an install article of a 25mm bar on an EJ1 (coming soon)!
Marcus
Old Oct 29, 2006 | 04:08 PM
2001B18C1GS-R's Avatar
how much for some integra visors shipped,aand this beaks kits with the bushing bar the whole package please send info to hd17f@yahoo.com
Old Nov 8, 2006 | 07:08 PM
MrHeeltoe's Avatar
Default Re: (2001B18C1GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R &raquo;</TD></TR><TR><TD CLASS="quote">how much for some integra visors shipped,aand this beaks kits with the bushing bar the whole package please send info to hd17f@yahoo.com</TD></TR></TABLE>
Believe we spoke in PMs!
Old Jan 14, 2007 | 11:09 AM
MrHeeltoe's Avatar
bump!
Old Jan 25, 2007 | 07:36 AM
MrHeeltoe's Avatar
bump!
Old Jan 25, 2007 | 08:06 AM
DCteg505's Avatar
how much for just the tie bar shipped 87111
Old Jan 25, 2007 | 11:10 PM
MrHeeltoe's Avatar
Default Re: (DCteg505)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCteg505 &raquo;</TD></TR><TR><TD CLASS="quote">how much for just the tie bar shipped 87111</TD></TR></TABLE>
PM y'all
Old Jan 26, 2007 | 02:58 PM
89EF9KID's Avatar
would the beaks lower tie bar fit an 89 civic hatchback?
Old Jan 26, 2007 | 02:59 PM
2000Ek's Avatar
Great Products, Great Prices, Outstanding Customer Service.
Old Jan 26, 2007 | 07:44 PM
MrHeeltoe's Avatar
Default Re: (89EF9KID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89EF9KID &raquo;</TD></TR><TR><TD CLASS="quote">would the beaks lower tie bar fit an 89 civic hatchback?</TD></TR></TABLE>
I think the 92-95 Civic one will, but can't say for waure...wanna try it? Return for refund if it doesn't work.
Old Jan 27, 2007 | 09:58 PM
MyEG6's Avatar
price for an eg beaks kit shipped to 92531?
Old Jan 29, 2007 | 11:52 AM
MrHeeltoe's Avatar
Default Re: BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!! (MyEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyEG6 &raquo;</TD></TR><TR><TD CLASS="quote">price for an eg beaks kit shipped to 92531? </TD></TR></TABLE>
There's a link in the first post to my shopping car. Not sure where it will bring you right now but these are pretty easy to find on there if you just look it up.
Old Jan 30, 2007 | 05:28 AM
punk_0333's Avatar
How much for the subframe kit for eg?
Old Jan 30, 2007 | 03:31 PM
MrHeeltoe's Avatar
Default Re: BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!! (punk_0333)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punk_0333 &raquo;</TD></TR><TR><TD CLASS="quote">How much for the subframe kit for eg?</TD></TR></TABLE>
Goto the link in the 1st post, look them up under suspension/sway bar!!!
BUMP!!! Updated post with new pics!
Old Feb 13, 2007 | 03:16 AM
92 BLUE EG6's Avatar
Are you offering any honda-tech discounts?
Old Feb 13, 2007 | 08:57 AM
MrHeeltoe's Avatar
Default Re: BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!! (92 BLUE EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 BLUE EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Are you offering any honda-tech discounts? </TD></TR></TABLE>
Occasionally.
Old Feb 21, 2007 | 12:09 PM
jdpfman's Avatar
how much for kit and the bar for an eg hatch?
Old Feb 21, 2007 | 05:04 PM
MrHeeltoe's Avatar
Default Re: BEAKS Suspension Products! EK, EG and DC Chassis! Prevent subframe tear-out!!!!! (jdpfman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdpfman &raquo;</TD></TR><TR><TD CLASS="quote">how much for kit and the bar for an eg hatch?</TD></TR></TABLE>
A sway bar or a tie bar?
Marcus
Old Feb 27, 2007 | 05:13 PM
M2S~Juan's Avatar
Can the tiebar be used by itself?
Old Mar 2, 2007 | 02:35 PM
MrHeeltoe's Avatar
Default Re: (juan01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juan01 &raquo;</TD></TR><TR><TD CLASS="quote">Can the tiebar be used by itself?</TD></TR></TABLE>
Yessir! I sell lone tie bars all the time
