EGR
Ok this is on my friends 99 v6. anyway hes been getting the egr code for awhile. He just replaced the egr valve itself and the light is still coming on. I told him to clean out the port where the egr sits on with carb cleaner ? Can this be anything else ?
there is a bulletin on it from Honda.........call the local Honda dealer see if there is any warranty consideration
the kit includes a sleeve that you have to install.. you need to drill the egr passage bigger, clean it up and insert the sleeve ...
it comes as a kit from Honda , it also includes the egr valve
Yes, When cars come to my dealership, The service writer will reccomend the kit, but when they come in i start talking to them, and i just tell em, you dont need the kit, i give em my number, and ill drill it out for them for 20 bucks....
How does the sleeve prevent the deposit build-up from happening again?
How do you keep the drilled out pieces from falling back down the hole?
And lastly, is't drilling it out dangerous? Can't you drill through the side of the tube?
Thanks,
-Will
Thanks,
-Will
Does anyone have the answer to these questions:
Thank You,
-Will
Thank You,
-Will
Here's the service bulletin for you to help answer your questions
http://members.troublecodes.ne...5.gif
The new sleeve is smooth steel and the idea is that the carbon won't be able to cling to it as easy as the cast aluminum.
Special drill bit with a WARNING not to drill too deep.
You can blow out the chips from the intake with compressed air.
krott5333
May 8, 2004 07:50 AM
