91 civic dash lights not working
Old Oct 20, 2006 | 02:40 PM
rust_free_civic's Avatar
Default 91 civic dash lights not working
I have a 91 civic lx and the dash lights and heater control lights dont work. All fuses are good and Im sure its not the bulbs. Please help
Old Oct 20, 2006 | 09:54 PM
EF_LSVtec's Avatar
Default Re: 91 civic dash lights not working (rust_free_civic)
replace the illumination switch/****. they go bad once in a while...
Old Oct 21, 2006 | 11:23 AM
Default Re: 91 civic dash lights not working (EF_LSVtec)
swapped it out and they still dont work
Old Oct 21, 2006 | 12:42 PM
philkehn's Avatar
I have the same problem in my rex... I cant find anyone that knows what wrong with it.. i went through 4 different switches and none of them worked so i know that its not my switch...
Old Oct 23, 2006 | 01:55 PM
Default Re: (philkehn)
I will let you when I figure it out, and I will figure it out
Old Oct 23, 2006 | 02:48 PM
boostedstd's Avatar
if all fuses are good and the dimmer switch, then look under your dashboard, right above the gas pedal should be a relay hanging off a braket. Make sure the harness is still plugged in and or swap out with another. This should solve your problem.
Old Oct 23, 2006 | 05:15 PM
placid888's Avatar
check for common ground between the 2 , good luck
hondacivic7007
Aug 27, 2017 10:04 AM
Silvertune
11
Apr 15, 2012 09:20 PM
92VXeg
Oct 17, 2010 05:26 PM
gavia111
Dec 23, 2005 05:50 PM
Jonathan_ED3
11
Aug 25, 2005 03:47 PM
