Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
speed sensor
Old Oct 20, 2006 | 12:36 PM
petty$rep's Avatar
Default speed sensor
Hey,
My mom has a 2001 Honda Oddesey. Her check engine light came on and it was the speed sensor. We replaced the speed sensor that was bad and the check engine light is still on.
Do you have to reset the ECU for the check engine light to go off or should it just go off after the sensor is replaced.
Also how do you reset the ecu.
thanx
Old Oct 21, 2006 | 04:55 AM
Ross 2.0's Avatar
In a Junkyard near you.
you have to reset the ecu. Just take it to autozone and they will do it free
Old Oct 24, 2006 | 01:57 PM
sfr4dr's Avatar
Default Re: (Ross 4107)
Did you disconnect the battery? Also a VSS code doesn't always mean just the sensor is bad. I went through this on my rodeo and they had to test connectivity from the sensor to the gauge cluster and then also check voltage at the cluster to make sure there isn't a problem with the cluster.
civic_66
12
Sep 14, 2008 12:24 PM
supaf1y
Jul 30, 2007 09:16 AM
94whitegsi
Aug 16, 2006 12:11 PM
purestreetracer
Jul 26, 2006 04:48 PM
shaveman
Aug 7, 2005 03:37 AM
