jdm cluster speedometer
Old Oct 20, 2006 | 11:34 AM
majek's Avatar
Default jdm cluster speedometer
I have a 96 civic hatch with auto trans and I just put in a jdm civic type r cluster but the speedometer is not working but the rpm is working. It was working with the stock cluster, do I have to change the wiring or something, Please help me. Thanks
Old Oct 20, 2006 | 11:55 AM
majek's Avatar
Default Re: jdm cluster speedometer (majek)
help
Old Oct 20, 2006 | 11:56 AM
SkoundrelUSA's Avatar
cute little bastard
If you're OG one worked fine, then theres something is wrong with the JDM one.
Old Oct 20, 2006 | 11:57 AM
dohcVTECeg2's Avatar
it should just be "plug N play". make sure you put the connectors in correctly.
Old Oct 20, 2006 | 12:00 PM
majek's Avatar
ok ill try see but it should work without changing the wiring
Old Oct 20, 2006 | 12:32 PM
BlueIntegraBoy's Avatar
Yes, it should work without any rewiring. Make sure the screws on the back of the speedometer are tight, but DO NOT overtighten.
Old Oct 20, 2006 | 10:26 PM
majek's Avatar
Default Re: jdm cluster speedometer (BlueIntegraBoy)
Thanks Ill try it tomorrow
eg6sittingon57cs
39
Nov 4, 2007 05:18 PM
92HatchB16
Aug 18, 2005 03:21 PM
tealjdmcrx
Jul 17, 2005 09:13 PM
EGJdmJreams
Nov 12, 2004 06:42 PM
Outkast_CL9
Jul 31, 2004 09:38 AM
