my brake light come on???
Old Oct 20, 2006 | 10:10 AM
eeleaj's Avatar
Default my brake light come on???
well like the title says my brake line come on when im driving??wtf.. my e-brake is down and when im cruising the brake light goes on for like a minute then goes off and does it again like every 5 minutes. i know its not that big a deal but it is very annoying. could something be loose?? i work all day so i thought id ask people here to see what they thought would be the problem before i jack the car up so i can check certain things. by the way i have a 93 civic HB CX./ any help would be a ppreciated
Old Oct 20, 2006 | 10:14 AM
96ls's Avatar
Default Re: my brake light come on??? (eeleaj)
check the fluid level in your master cylinder.
Old Oct 20, 2006 | 11:44 AM
Mr Hammond's Avatar
a/k/a Jomo
Check your master cylinder fluid level. If it's low, fill it up and see if the light goes away. Make sure to also check for leaks, especially in the rear wheel well (rear wheel cylinders going bad). Have you noticed a decrease in braking performance? Softness in the pedal?
If the fluid is fine, no leaks, and pedal feels ok, master cylinder cap probably needs to be replaced.
Old Oct 20, 2006 | 11:53 AM
dohcVTECeg2's Avatar
Default Re: my brake light come on??? (Mr Hammond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">Check your master cylinder fluid level. If it's low, fill it up and see if the light goes away. Make sure to also check for leaks, especially in the rear wheel well (rear wheel cylinders going bad). Have you noticed a decrease in braking performance? Softness in the pedal?
If the fluid is fine, no leaks, and pedal feels ok, master cylinder cap probably needs to be replaced.</TD></TR></TABLE>
this is your best bet
Old Oct 20, 2006 | 12:13 PM
slowmovingegg's Avatar
same thing happened to me. i filled up the master cylinder and the brake light just went away. i also have a 93 hb cx. so that should work.
Old Oct 20, 2006 | 07:25 PM
eeleaj's Avatar
Default Re: my brake light come on??? (slowmovingegg)
thanks for the help guys im try that and if it doesnt go away ill be back for more suggestions
Old Oct 20, 2006 | 07:33 PM
SNYPR2's Avatar
check the fluid level first off, and if it's good and you have no leaking seals see if the car will give you a light while idling and disconnect the master cylinder resevoir cap if it goes away you have a faulty cap.
Old Oct 21, 2006 | 12:56 PM
eeleaj's Avatar
Default Re: my brake light come on??? (SNYPR2)
i found the problem. the fluid was just low enough to trigger the light to come on. thanks for your guys helps i really appreciate it
03--Accord--03
Jun 5, 2017 06:15 AM
DoobieMarks101
Aug 20, 2008 07:20 AM
tegsallgood
Oct 26, 2004 11:50 AM
Jinya1004
13
Jul 3, 2004 01:48 PM
speedaholic92
Jan 21, 2004 09:20 AM
