Poly UCA Bushings?
Old Oct 20, 2006 | 07:57 AM
mymeatb18
Default Poly UCA Bushings?
i have a DC and my UCA bushings are gone on the driverside. i was thinking of just gettin some polyurethane ones for both sides since im changing them.
i wanted to know if any of you guys have any opinions on them and how hard it would be to change. IE: can i put these bushings in myself without a press?
thanks
Old Oct 21, 2006 | 07:15 AM
mymeatb18
Default Re: Poly UCA Bushings? (mymeatb18")
bump
Old Oct 21, 2006 | 12:35 PM
jvtec95's Avatar
http://www.orijinmotorspots.com
far better than poly.
And yes, you can replace them yourself, they are easily done.
Old Oct 21, 2006 | 06:03 PM
Sam92Teg's Avatar
Do you plan on lowering the car in the foreseeable future? If so, kill two birds with one stone and get an upper arm camber kit ($150) or anchor bolt camber kit ($90). Both of these will have the new bushings already, and can be adjusted for your stock or lowered heights.
Old Oct 22, 2006 | 07:09 AM
mymeatb18
Default Re: Poly UCA Bushings? (Sam92Teg)
well the car is lowered already and im not a big fan of camber kits, i like camber as well. im not dumped nor wil i ever be so i can live with the little camber that i have. but thanks for the responses guys
Old Oct 22, 2006 | 07:49 AM
be18see1's Avatar
i have poly uca bushings, and i used a press to get them out, and i would recommend you secure one. i redid all my bushings with poly ones and i noticed a considerable difference from sotck suspension w/ rubber.
Old Oct 22, 2006 | 08:52 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i installed a whole es master kit with no press at all. i just used a c-clamp. when that didn't work, i just lined everything up, put the parts between a couple pieces of wood, and stepped on it. it took a little time, but it worked.
Old Oct 22, 2006 | 09:57 AM
be18see1's Avatar
Default Re: (full Circling)
impressive. i couldnt get some of them out with a 20 ton press so iono how you did it with wood and body weight.. i actually still have some i havent done yet. i think theyre for the sway bar and shift linkage. anyway..
edit-if you do decide to get/use a press. be sure to have some sockets on site so that you can press the bushing out, otherwise, youll bend the uca/lca/whatever else it is, like i did. then you spend the next 6+ hours cussing out a piece of cast steel while trying to get it back to factory specs.
Old Oct 22, 2006 | 10:11 AM
oh, i forgot to mention, i burned all of the old bushings out with a propane torch. it gets smoky, but it's an easy way to DIY w/o a press.
some of the bushings will have metal outer rings that will still remain after the rubber is burned out. i just used a dremel to cut them out. this is the easiest way to do the job without a press.
Old Oct 22, 2006 | 12:50 PM
mymeatb18
awsome thanks guys bought some poly bushings today looking foward to changing them
Old Oct 22, 2006 | 12:58 PM
be18see1's Avatar
Default Re: (mymeatb18")
be VERY careful if you cut the rings, and if you do, make sure you sand out the insides bc one little burr will destroy a poly busing over time.
Old Oct 22, 2006 | 08:29 PM
mymeatb18
Default Re: (be18see1)
so just make it smooth basicly.?
Old Oct 23, 2006 | 07:11 AM
be18see1's Avatar
yeah, very you should be able to run your fingers through and feel nothing at all including the rim of the ca
Old Oct 23, 2006 | 11:26 AM
mymeatb18
chrisbell37
15
Jul 30, 2006 02:40 PM
95slomocivi
Feb 23, 2006 03:48 PM
nfinitecc
Feb 24, 2005 07:35 AM
eTec
19
May 21, 2002 04:51 AM
