Replacing antenna!
ok first off
first post here guys been reading on honda-tech for a long time and just made an account today.
second i have seen the Replacing antenna forum in the crx part of the forums and i didnt want to post in there sincec its the wrong section. i have a question about my 93 civic hatch back
here it is
i have took out the old antenna and when to put the new antenna in and for the life of me can not get the wire to go down the pillar. well i can get it most of the way down i can here it moving around but no clue on how to make it go down the rest of the way i have tryed a coat hanger pushing it down there it got further but then stops like feels like its hitting somthing and when i get under the dash to see if i could see the wire threw that hole nothing any suggestions.
thanks in advance
here it is
thanks in advance
its tricky... you can try twisting/spinning the antenna while you feed it down the pillar.
Also, mark off the length that it would take for the wire to reach the hole in the kick panel.. that way when you get it all the way to your mark, you can then reach your hand inside the car at the kick panel and grab it...
it will go, but it can be really frustrating..
Sorry you had to learn the hard way to tie a piece of string to the old ant before you pull it out. As far as getting it back in use a hanger or stiff wire feed it up the pillar and tape the new ant to it and pull it back out
W0oT
Nov 4, 2002 07:06 AM
