Tach Install Trouble
Old May 4, 2002 | 07:44 PM
MetalKill's Avatar
Default Tach Install Trouble
having a little truoble with this tach. i got the power to it its grounded and its conected to the distributor...but i cant figure out how to hook it up to my dimmer can anyone help me with this i have a 2000 civic coupe dx thx.
Old May 4, 2002 | 08:43 PM
civicb18b's Avatar
Default Re: Tach Install Trouble (MetalKill)
Don't go in the engine. Just wire it all inside the car. Ground to chasis. Red to a power source. And the other color, which I forget, to the ignition (yellow wire).
Old May 4, 2002 | 08:57 PM
MetalKill's Avatar
Default Re: Tach Install Trouble (civicb18b)
i have it grounded, powered, and hooked to the distributor...now i need it to be hooked to the dimmer
Old May 4, 2002 | 09:00 PM
civicb18b's Avatar
Screw the dimmer! Why didn't you just get an EX cluster to begin with?
Old May 4, 2002 | 09:37 PM
MetalKill's Avatar
tach = cheaper
Old May 4, 2002 | 10:35 PM
BrandonClaps's Avatar
New User
the tach wire is right behind the gauge cluster
Old May 5, 2002 | 12:30 AM
99DXcoupe's Avatar
just go there man http://www.home.mpinet.net/t-hero/Tach!!.htm
Old May 5, 2002 | 03:59 AM
AP1@9K's Avatar
just look in the inside fuse box for "headlight" or "parking light" fuse and install that wire in with the fuse. That's how i installed my tach a while back in my ek.
Old May 5, 2002 | 06:21 AM
primoEF's Avatar
don't go to the dimmer, you will fu*k thing up, just pull one of the plugs that will light up when parking light is on and use a test light to find the paking light wire and tap into it, that the source for the light
streetcartuner
Sep 8, 2006 07:19 PM
99sibluehatchwitb16
Jan 26, 2006 12:47 AM
ironchef25
16
Aug 26, 2004 06:55 PM
Simon Tibbett
Feb 8, 2004 09:22 AM
kappy
Jul 17, 2001 01:05 PM
