wiseco b16 piston help.....
Old Oct 19, 2006 | 11:51 PM
oerski's Avatar
Default wiseco b16 piston help.....
okay i just purchased these
Race Engineering part # XT527P81 (R18305178) 81mm bore 1.186 comp height. comp in a b16 should be 11:1 according to RE. looked around on here and some other sites for confirmation, but if i put these in my poor mans R. stock head gasket, no milling, (i am assuming its possible) the compression should yeild a bit higher than in a b16 right. just dont know how to make sure the Comp wont be too hight. comparible compression height Wisecos suggest 11.8:1 ish comp. any clue. did i jump the gun blinded by a good deal on the slugs? also going on eagle ESPs and running jun3s. Clay i will be doing if i cant get any confirmation. hell ill do it anyway.
Old Oct 20, 2006 | 04:08 PM
oerski's Avatar
Default Re: wiseco b16 piston help..... (oerski)
bump....
Old Oct 21, 2006 | 11:35 AM
Mr Hammond's Avatar
a/k/a Jomo
That sounds about right. Without knowing the specs on the pistons, I can't give you an exact answer.
As an example though, B16A2 compression is 10.2:1. Put those same pistons in a "Poorman's ITR" and the compression is 11:1.
Old Oct 21, 2006 | 06:10 PM
oerski's Avatar
thats what i was thinking when i purchased them. ill post up all the specs when they come in...
Old Oct 25, 2006 | 07:28 PM
oerski's Avatar
bump...
black99x
Aug 13, 2006 01:23 PM
7rrivera7
Oct 20, 2003 04:55 PM
SolidSpruce
Aug 27, 2003 05:35 AM
