just swapped a 2000 civic si cluster in my rex..need some help please!!!
Old Oct 19, 2006 | 12:02 PM
efrex's Avatar
Default just swapped a 2000 civic si cluster in my rex..need some help please!!!
i have a 91 crx si,b16.....i posted in the that other thread made by the guy who started this whole thing a while back but i never got any help from there..so i hope i can get some help on here..so here i go....ok.the only problems i seem to be having are ..the brightness control doesnt seem to work and i wired that up correct....and the other is the speedometer...there are 3 wires from the electronic speed sensor that i got from a d series...theres a black...yellow/black....and white/blue.....i grounded the black one....the yellow/black i assumed was the signal wire.so i split the wire and wired it up to pin a11 on the cluster and to pin b16 on the ecu...and the white/blue to power but the speedo isnt working......did i wire it up wrong? could someone help me out.please..thanks
Old Oct 19, 2006 | 02:59 PM
efrex's Avatar
Default Re: just swapped a 2000 civic si cluster in my rex..need some help please!!! (efrex)
anyone?
Old Oct 19, 2006 | 03:12 PM
doublethink's Avatar
ok looking at the helms it says the colors are as follows:
for a 92-95 civic:
Black = Ground
Yellow/White = VSS Signal to cluster/ECU
Yellow/Blue = Ignition Power
for a 96-00 civic: (which is the one it seems you have)
Black = Ground
Blue/White = VSS Signal to Cluster/ECU
Black/Yellow = Ignition Power
your welcome.
Old Oct 19, 2006 | 03:14 PM
project midnight's Avatar
well i doubt anyone here has done it and i know very little about wiring but maybe some photos would help whoever wants to help you.
Old Oct 19, 2006 | 03:30 PM
efrex's Avatar
Default Re: just swapped a 2000 civic si cluster in my rex..need some help please!!! (doublethink)
ok..yea i do have the 96-2000 vss...ill try rewire and let u know how it goes....thanks alot..i really appreciate this
Old Oct 19, 2006 | 04:29 PM
APEX CRX's Avatar
there are a few variations on VSS wire colors. I would switch the signal and power wires and see if the speedo works after
Old Oct 19, 2006 | 05:10 PM
efrex's Avatar
Default Re: (APEX CRX)
ok im back.....the white/blue is signal and black/yellow is power....its all done and working fine...thanks so much guys
Old Dec 3, 2006 | 05:28 PM
efrex's Avatar
Default Re: (efrex)
i didnt wanna make another thread.so im bringing this one back.hope thats fine.....the cluster has been working fine except for 2 things...the needles dont glow and the brightness control doesnt work and the wiring is done correctly.i have checked it over and over again....anyone that has done this swap,having this problem? and did you fix it and how?....thanks in advance
heres 1 picture
Old Dec 3, 2006 | 06:38 PM
B6tizzleHatch's Avatar
Default Re: (efrex)
here is everything you need to know!
http://faq.ef-honda.com/index....ng=en
Old Dec 3, 2006 | 07:03 PM
efrex's Avatar
Default Re: (B6tizzleHatch)
thanks.but i already know everything on there.i appreciate it........my problem is....the cluster lights up.i can see the numbers but the needles dont light up
Old Dec 5, 2006 | 04:12 PM
efrex's Avatar
Default Re: (efrex)
anyone?
Old Dec 5, 2006 | 04:47 PM
90b20vteckidd's Avatar
Default Re: (efrex)
dude come on, its the bulbs that go on top of the cluster.
your not very good at noticing stuff are you
Old Dec 5, 2006 | 04:50 PM
mrtoastyjr's Avatar
Default Re: (90b20vteckidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b20vteckidd &raquo;</TD></TR><TR><TD CLASS="quote">dude come on, its the bulbs that go on top of the cluster.
your not very good at noticing stuff are you</TD></TR></TABLE>
wow, that was uncalled for.
anyway, hes right. the needles don't glow/light up really. there a bulb on top of the cluster shineing down on the front of the faces, like a stock crx/civic cluster, which illiuminates the needles. see if the bulb is blown. of mabey not even plugged in
Old Dec 5, 2006 | 04:52 PM
efrex's Avatar
Default Re: (mrtoastyjr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrtoastyjr &raquo;</TD></TR><TR><TD CLASS="quote">
anyway, hes right. the needles don't glow/light up really. there a bulb on top of the cluster shineing down on the front of the faces, like a stock crx/civic cluster, which illiuminates the needles. see if the bulb is blown. of mabey not even plugged in</TD></TR></TABLE>
its ok..i dont really pay attention to unhelpful newbies........thanks but i have replaced it twice..maybe those 2 bulbs didnt work..ill buy more and see what happens..i appreciate it
Old Dec 5, 2006 | 05:01 PM
mrtoastyjr's Avatar
Default Re: (efrex)
try checking for voltage going to those sockets. mabey there something wrong with the cluster. it won't be the first time that ive seen the circuits on the back fried
teler86
May 24, 2006 09:32 PM
gringo7718
Apr 5, 2004 12:44 AM
B20zvtecek
Dec 3, 2002 09:11 PM
