Suspension & Brakes Theory, alignment, spring rates....
si rear swaybar to DX EK
Old Oct 19, 2006 | 12:01 PM
timmy0tool's Avatar
Default si rear swaybar to DX EK
quick questions, quick answers...let's go!
i have a 96 DX coupe and obtained an 99 si rear swaybar. i know the subframe has the holes but are they threaded? do i need to reinforce the backside like most kits do? also what endlinks besides 99 si can i use? in advance!
Old Oct 19, 2006 | 12:28 PM
JDMFreak's Avatar
Default Re: si rear swaybar to DX EK (timmy0tool)
IMO, if your using the stock 99-00 Si. you will have no problem, as long as you have the endlink & D-brakets (i hope your not just talking about the bar itself) as well
Old Oct 19, 2006 | 02:02 PM
nonsense's Avatar
ok, you need this from the Si:
#27 - sway bar
#30 - bracket
#31/32 - Si end links
#29 - 13mm bushing
#28 - D-bracket
Plus all the hardware to bolt it up.
Old Oct 19, 2006 | 04:37 PM
timmy0tool's Avatar
thanks guys for the response, but my question was never answered. is the subframe threaded?
i have all the parts besides the endlinks.
Old Oct 19, 2006 | 07:52 PM
MilanoCivic97's Avatar
Default Re: (timmy0tool)
no, the subframe is not threaded. you will need nuts to secure them...kinda a PITA to put on IMO. no subframe reinforcement is needed. all you need it the bushings, brackets, bolts, and endlinks. i have this on my 97 ex
Old Oct 19, 2006 | 08:08 PM
EK k kay's Avatar
Default Re: (MilanoCivic97)
Not threaded. Go down to the hardware store and grab some nuts/bolts and lock washers.
Old Oct 20, 2006 | 01:33 PM
Plum_civicEK's Avatar
this is how it looks like at the end.
notice those silver bolts?? you'll need to buy those bolts and nut to install the bracket :D
Old Oct 22, 2006 | 11:59 PM
EJse7en's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy0tool &raquo;</TD></TR><TR><TD CLASS="quote">quick questions, quick answers...let's go!
i have a 96 DX coupe and obtained an 99 si rear swaybar. i know the subframe has the holes but are they threaded? do i need to reinforce the backside like most kits do? also what endlinks besides 99 si can i use? in advance!</TD></TR></TABLE>
I also want to know what other endlinks can work besides oem SI. Blox has these similar endlinks, which are a tad bit shorter, but i am not sure if it would be compatible with an SI or 14mm integra sway, since they are advertised for bigger applications.
Old Oct 23, 2006 | 07:04 AM
nonsense's Avatar
Default Re: si rear swaybar to DX EK (EJse7en)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJse7en &raquo;</TD></TR><TR><TD CLASS="quote">
I also want to know what other endlinks can work besides oem SI. Blox has these similar endlinks, which are a tad bit shorter, but i am not sure if it would be compatible with an SI or 14mm integra sway, since they are advertised for bigger applications.</TD></TR></TABLE>
those should work fine.
Old Oct 23, 2006 | 02:16 PM
timmy0tool's Avatar
i too was looking into the blox endlinks. honda OEM si endlinks are way too expensive compared to the newer or older endlinks (kinda weird). anyone know for sure the blox endlinks work?
geneeunit
10
Mar 27, 2009 04:12 PM
VeilSide_Mas
Aug 19, 2006 03:39 PM
FifthGearOnline
Jul 27, 2003 06:19 PM
FifthGearOnline
10
Mar 3, 2003 01:02 PM
Hayasa15
Feb 22, 2002 07:29 PM
