Suspension & Brakes Theory, alignment, spring rates....
cambe kit worthy?
Old Oct 19, 2006 | 11:15 AM
Robstunner4's Avatar
Default cambe kit worthy?
ill make this short and sweet.
1.75F 1.5R drop neuspeed sports.
pics:
Old Oct 19, 2006 | 11:36 AM
Tyson's Avatar
Default Re: cambe kit worthy? (Robstunner4)
you need a toe alignment.
Old Oct 19, 2006 | 07:12 PM
qfast817's Avatar
Default Re: cambe kit worthy? (Tyson)
might as well do it right the first time
Old Oct 21, 2006 | 08:18 AM
bsixteen's Avatar
i had the neuspeed sports(dunno if thats what you have) and i didn't need camber adjustment.
Old Oct 21, 2006 | 08:23 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You do not need a camber kit. Just get a regular alignment and rotate tires often. If a mechanic tells you that you need one, tell him to suck it
Old Oct 21, 2006 | 08:14 PM
RSX-R's Avatar
Default Re: (PatrickGSR94)
you will only need a camber kit if you lower it like until the upper control arms start bending. lowering it about an inch wont need a camber kit.
Old Oct 22, 2006 | 07:38 PM
Community Builder
Default Re: (RSX-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RSX-R &raquo;</TD></TR><TR><TD CLASS="quote">you will only need a camber kit if you lower it like until the upper control arms start bending. lowering it about an inch wont need a camber kit.</TD></TR></TABLE>
bending? suspension parts should NEVER bend whatsoever.
I used to be lowered nearly 3", now more like 1.75", never used a camber kit.
Old Oct 22, 2006 | 08:44 PM
hayabusa160's Avatar
i wish i never got the skunk2 uppr arms in front they are hitting the body of the car when i hit big bumps it sucks alot now i need to find some stock ones.
Old Oct 23, 2006 | 04:17 PM
dvp's Avatar
dvp
Default Re: (hayabusa160)
"Need" a camber kit?? If you have 3* negative camber and you only track the car do you "need" a camber kit?
It comes down to whether you want one or not. If you will never be changing the suspension and the camber is in an acceptable spot for you then don't buy one. But as already stated you need to get the toe to zero (for the best tire wear).
Showing pictures isn't going to help anyone. All we can tell is there is some camber there. How much? Do you ever autocross the car, HPDE??
v8 killer
Honda Civic (2006 - 2015)
Mar 9, 2012 04:02 PM
d0ugch0i
Suspension & Brakes
Oct 22, 2007 04:08 PM
4drteg916
Suspension & Brakes
Feb 22, 2007 12:07 PM
MSP
Jan 13, 2005 02:13 AM
AcCorD 9dfive
Aug 17, 2003 05:53 PM
