car is hesitent to start sometimes
Old Oct 19, 2006 | 07:54 AM
skata89's Avatar
Default car is hesitent to start sometimes
Well sometimes when I start my car up it wont turn over. Ill try it a couple of times and it will finally start up. I cleaned my grounds, i have a new starter, and i hear the fuel pump priming. anyone have any suggestions to why its doing this?
Old Oct 19, 2006 | 08:28 AM
forumnoobie's Avatar
Default Re: car is hesitent to start sometimes (skata89)
clogged fuel filter?
Old Oct 19, 2006 | 09:22 AM
skata89's Avatar
na i dont think thats it bc i just replaced that like 2 months ago. could it be clog fuel injectors maybe?
Old Oct 19, 2006 | 09:54 AM
skata89's Avatar
I think its the clutch interlock swith. the one right above the clutch pedal. bc itll start after pumping the clutch. I just cant locate the switch and im not quite sure what to look for. I know its on top but i dont see anything that looks like a switch.
Old Oct 19, 2006 | 11:40 AM
skunked's Avatar
Default Re: (skata89)
It won't crank right? If so, it sounds like the starter since the fuel pump is priming.
Old Oct 19, 2006 | 01:20 PM
Solscud007's Avatar
look up under the clutch. at the top there is a whitish plastic round cylinder. that pushes on the switch when the clutch is not pressed. so in the relaxed position the switch is pressed. the switch will face towards the engine bay.
Old Oct 19, 2006 | 04:39 PM
skata89's Avatar
Well I just replaced the starter not to long ago with a new one. not a rebuilt. so you think it mite be that?
magicmyst98
14
Sep 2, 2013 12:06 PM
zerovandez
Apr 1, 2011 01:05 PM
obuhmyuh
10
May 4, 2010 02:15 PM
03K24A4EX
May 26, 2006 04:47 AM
DrewQ1
May 4, 2004 09:14 PM
