Rear Disc Conversion ?
Old Oct 19, 2006 | 05:02 AM
Snailed EF's Avatar
Default Rear Disc Conversion ?
I was wondering will a 99-00 Si rear disc setup fit my 90 Si is it direct bolt and will the e-brake cables from the 99-00 si work also. I have both of these for free because my g/f recked a 99-00 Si so any info about this swap will be appritiated.
Old Oct 19, 2006 | 05:37 AM
CRX Toad's Avatar
Default Re: Rear Disc Conversion ? (Snailed EF)
I was wondering if you could search considering when you posted this thread https://honda-tech.com/zerothread/1785700 was right under it.
E-brake cables must be from a 90-91 CRX Si.
Old Oct 19, 2006 | 07:09 AM
Snailed EF's Avatar
i had a feeling a was goin to get that answer but yea i did search and i couldnt find anything bout 99-00 Si rear discs so im guessing it is a direct bolt though
Old Oct 19, 2006 | 07:21 AM
CRX Toad's Avatar
Default Re: (Snailed EF)
Direct bolt in, use your stock UCA, LCA and you will need to get CRX Si e-brake cables unless you car is a Si Hatch then you will have to use Integra or the Civic Disc brake cables.
Old Oct 19, 2006 | 07:41 AM
Snailed EF's Avatar
ok good it is an Si
Old Oct 19, 2006 | 07:43 AM
Snailed EF's Avatar
thanks man appritiate the help
devietb0i
Northern California (Sales)
Apr 8, 2008 06:48 PM
candyman206
Jan 26, 2008 05:56 PM
BMRALR
Jan 7, 2008 11:43 AM
818SpoonITR
Nov 1, 2006 12:06 PM
scratchy
Jan 27, 2004 06:21 AM
