Yet another crankshaft pulley bolt removal method
Old Oct 18, 2006 | 10:33 PM
clayne's Avatar
Default Yet another crankshaft pulley bolt removal method
None of this stuff is rocket science or anything new, but more options are always good to have, so I figured I'd throw this out there. This is what I use after the block is out of the car and transmission is off: just 1/8" thick flat stock from Home Depot w/ holes drilled through it. In the pics below I am using it to tighten the pulley bolt. If you were loosening, I'd reposition the metal or choose a different bolt hole so that it is always under tension and won't bow under load.
Jack handle + breaker bar + 19 mm socket + 1 flywheel bolt + 1 trans bolt:
Old Oct 19, 2006 | 10:39 AM
astig* DC2's Avatar
Default Re: Yet another crankshaft pulley bolt removal method (clayne)
FUNNY COZ I JUST TOOK MINE OUT COUPLE WEEKS AGO USING THE SAME METHOD..ONLY DIF IS THAT I USED ONE OF THE ENGINE STANDS ARM..
Old Oct 19, 2006 | 07:19 PM
boostedblkef's Avatar
Default Re: Yet another crankshaft pulley bolt removal method (k4SP3R)
i find an air gun works best
Old Oct 19, 2006 | 10:25 PM
TwoKSiR's Avatar
I like a pry bar (or big screwdriver)on the started gear on the flywheel.
beansandrice
Jun 27, 2011 02:01 PM
BobS95v6
Mar 28, 2010 11:02 PM
projsectEF
Sep 21, 2007 03:53 PM
chrdal
Feb 18, 2003 08:24 AM
GruvyTune
Jun 15, 2002 01:19 PM
