itr cams w/ turbo?
I was trying to swap my N/A Skunk2 stg 2's for standard ITR/CTR cams as I'm going boost now.
So your saying I'll be ok using them?
Anything else I need to consider when using them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGUK »</TD></TR><TR><TD CLASS="quote">I was trying to swap my N/A Skunk2 stg 2's for standard ITR/CTR cams as I'm going boost now.
What manifold are you running?
BTW, I'm running ITR cams also.
</TD></TR></TABLE>What manifold are you running?
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">what about a itr intake and gsr exhaust?</TD></TR></TABLE>
definately run the ITR/CTR intake cam, theres no real difference between the GSR and ITR/CTR exhaust cam
I got a ? for you adSpeed. We're in the process of building a 2020 ls/vtec fully built obviously with a Shearer fab divided t4 manifold and a gt42 and we were def looking into getting cams. The thing is that itr/ctr cams are so F*(&&% expensive that I'd rather buy aftermarket cuz they're cheaper!! I was looking at either skunk 2 or comps cams for this setup. Whats your opinion on that?
Thanks
Ryan
Thanks
Ryan
I am also interested in the benifit of ctr intake cam with gsr exhaust. I am currently making 275whp now on 7psi on my jdm gsr stock motor.
I want to do:
ctr intake cam
blox intake manifold
cam gear tuning
maybe up the boost to 10
I know some of this is off topic, i just want to know about the cam if possible, Thanks!
I want to do:
ctr intake cam
cam gear tuning
i was wondering if the gsr exhaust with the itr intake would hold boost better. kind of like trapping it in the combustion chamber for just a little longer than the intake cam? any ideas? whatever is going to make the most power obviouly.
like i said before, gsr, itr, ctr cam will be alot easier to tune because itll make your power band alot more linear.. big cams are thirsty, little more dificult to tune, but you can also play with the overlap and as far as a big cam id say go with a skunk2 stage 2s for boost, and just dont run oversized valves with it... big displacement, stock size valve, make sure you measure your ptv clearance also with the big cam... but as far as a race car, and alot of power at a low boost level, RUN BIG CAMS.. SKUNK2
Not to thread jack but I have a 95 integra gsr with 57trim t3/t4 turbo set at 7psi on a stock block. Would i benefit if i just bought an ITR intake camshaft and just dropped it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">ok but what about using different intake and exhaust. i have 3 sets of cams. b16, gsr, itr. what is the best combo?</TD></TR></TABLE>
go with the ITR set, the ITR intake cam for sure and either the GSR or ITR exhaust cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">Not to thread jack but I have a 95 integra gsr with 57trim t3/t4 turbo set at 7psi on a stock block. Would i benefit if i just bought an ITR intake camshaft and just dropped it in?</TD></TR></TABLE>
thats pretty much my question! from what i have been reading it will help a little, but nothing crazy, but then its all in the tune!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR »</TD></TR><TR><TD CLASS="quote">
BTW, I'm running ITR cams also. </TD></TR></TABLE>
I'm running BBK intake with 70mm T/B?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED »</TD></TR><TR><TD CLASS="quote">perfect, then run big cam</TD></TR></TABLE>
Skunk2's Stg2's it is then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic »</TD></TR><TR><TD CLASS="quote">I am also interested in the benifit of ctr intake cam with gsr exhaust. I am currently making 275whp now on 7psi on my jdm gsr stock motor.
I want to do:
ctr intake cam
cam gear tuning
I know some of this is off topic, i just want to know about the cam if possible, Thanks!</TD></TR></TABLE>
do not waste your money on a blox intake manifold, if your gonna get a im get victor x, or something bigger.. dont do skunk2 or blox, , dont wory about cam gear tuning unless you go big cams, up the boost to 10 ish youll be 300 plus easily depending on what turbo your gonna run.. gl
I want to do:
ctr intake cam
cam gear tuning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED »</TD></TR><TR><TD CLASS="quote">if u dont mind me asking, what is gonna be your turbo setup??</TD></TR></TABLE>
I'm using a Peakboost topmount with 4in D/P with GT30R turbo.
