Need help with a crappy running SiR-II swap in a 99EX
Problem is after my car has been running for about 10 minutes and I give it any amoun of gas, it starts to misfire/break up. When it first starts, it is fine. Only exception is if it was breaking up befor I shut it off, it will still break up for about a minute and then it is fine for about 10 minutes. When I say start, I mean it has not been runnning for atleast a few hours.
I have changed plugs, wires, distributor cap and rotor, and ignition coil inside of the distributor.
The engine used to break up a little and I would change the distributor cap and rotor and it would run fine for 4 months or so. I did the swap about a year and a half ago.
any info would be greatly appreciated
Tank8677
Feb 1, 2005 02:31 PM
phoboyjimmy
Oct 14, 2002 08:38 AM
