v tech kicks in around 4500 ish .... but by 6500 i loose power till redline. why?
Old Oct 18, 2006 | 11:25 AM
3s0n3's Avatar
Default v tech kicks in around 4500 ish .... but by 6500 i loose power till redline. why?
this is a 91 rex si with a 99 obd2 gsr with very low miles. it worked fine for 300 miles and this just started. brand new clutch and fly. all connectors are tight and grounds are good.
anyone?
Old Oct 18, 2006 | 11:48 AM
onepoint6i's Avatar
Default Re: v tech kicks in around 4500 ish .... but by 6500 i loose power till redline. why? (3s0n3)
hows your oil level?
Old Oct 18, 2006 | 12:26 PM
RockinthEFhatch's Avatar
VTEC... not v tech.
Old Oct 18, 2006 | 12:27 PM
Is the check engine light on, are you throwing any codes? Are you going faster than 26 mph? Check all wiring again.
Old Oct 18, 2006 | 12:47 PM
highroller54's Avatar
Default Re: v tech kicks in around 4500 ish .... but by 6500 i loose power till redline. why? (RockinthEFhat
cat plugged?
Old Oct 18, 2006 | 02:47 PM
3s0n3's Avatar
test pipe, one code but its for the second o2 sensor and its just a polarity issue, oil level is good and you can hear it kick on it works fine sometimes it seems to act up in like 3 and 4th and by act up i mean lag in the high top end 7-8k like the clutch is not adjusted right. but that does not explain y it works sometimes
Old Oct 18, 2006 | 03:21 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (3s0n3)
are you using the GSR manifold with IAB's? If so are you using a PR3 ECU? If so you're secondaries aren't opening
Old Oct 18, 2006 | 03:37 PM
Targa250R's Avatar
be professional
Default Re: (HondaPartsHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero &raquo;</TD></TR><TR><TD CLASS="quote">are you using the GSR manifold with IAB's? If so are you using a PR3 ECU? If so you're secondaries aren't opening</TD></TR></TABLE>
VTEC should be engaging at 4400 RPM and the intake manifold should be opening the short runners at 5750 RPM with a P72 ECU. It sounds like the intake manifold is not functioning properly.
Old Oct 18, 2006 | 04:09 PM
3s0n3's Avatar
it is a 99gsr p72. how would i go about trouble shooting that
LLK KING
18
Jul 10, 2009 09:53 AM
lee0149
Engine Management and Tuning
Nov 10, 2008 11:04 AM
Year2000
Nov 9, 2005 04:34 PM
1ntensiveVTECivic
Nov 15, 2003 07:22 PM
