Exhaust out of aluminum?
Old Oct 18, 2006 | 09:33 AM
CBURKE's Avatar
Default Exhaust out of aluminum?
Would this be a good idea? I am building a CRX drag car and trying to get a little more edge.
What would be the good and bad about this?
It will not see a lot of daily driving but maybe some.
Old Oct 18, 2006 | 10:22 AM
91TSiGuy's Avatar
Default Re: Exhaust out of aluminum? (CBURKE)
It is definitely feasable. Most people are doing downpipe-back in aluminum and stainless for the front (this is how I'm doing it on my car as well) but while at E-town this past weekend I saw two twin turbo mustangs with GT42r's that had aluminum right off the turbo. I'm hearing about a few other people doing this too, although these are strictly drag cars.
Old Oct 18, 2006 | 10:55 AM
GeeGee's Avatar
cooler after-turbo exhaust temp and less weight.
Old Oct 18, 2006 | 11:10 AM
CBURKE's Avatar
this is what I was thinking so cool, I am not doing a turbo on this car but I am just getting as my wight off as I can with out ripping the car apart. I'll be running this all they way back, I guess it would weigh like next to nothing.
Old Oct 18, 2006 | 12:06 PM
trickeng's Avatar
Default Re: (CBURKE)
Ti titanium would be a better solution for weight because it will not crack like the aluminum is going to on a street car.
Old Oct 18, 2006 | 12:14 PM
b16hybridsol's Avatar
Default Re: (GeeGee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GeeGee &raquo;</TD></TR><TR><TD CLASS="quote">cooler after-turbo exhaust temp and less weight.</TD></TR></TABLE>
why would you want your exhaust temps to cool that quickly after the turbo? I see no advantage
Old Oct 18, 2006 | 05:21 PM
david@didrace.com's Avatar
Default Re: (b16hybridsol)
I think he's saying that you can't have an aluminum exhaust before the turbo because of the high heat, but after it is fine.
Old Oct 18, 2006 | 07:40 PM
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">
why would you want your exhaust temps to cool that quickly after the turbo? I see no advantage</TD></TR></TABLE>
I know you want it to expand as much as possible.. I'm not sure about the cooling part... I'll try to research that tonight... I'm sure tony1 or somebody would know this though..
Old Oct 18, 2006 | 07:58 PM
Shepherd's Avatar
Default Re: (dmoto)
The whole point of an engine is to get air "in" as fast as possible and exhaust "out" as fast as possible.
Since hot exhaust moves faster, the goal should be to keep the exhaust as hot as possible.
Old Oct 18, 2006 | 08:09 PM
dmotoguy's Avatar
Default Re: (Shepherd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shepherd &raquo;</TD></TR><TR><TD CLASS="quote">The whole point of an engine is to get air "in" as fast as possible and exhaust "out" as fast as possible.
Since hot exhaust moves faster, the goal should be to keep the exhaust as hot as possible.</TD></TR></TABLE>
that is true on a N/A car... but the turbo changes this
Old Oct 18, 2006 | 09:18 PM
Shepherd's Avatar
Default Re: (dmoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmoto &raquo;</TD></TR><TR><TD CLASS="quote">
that is true on a N/A car... but the turbo changes this</TD></TR></TABLE>
In what sense?!
An engine is an engine. It wants air in, exhaust out. Just because a turbo consumes a portion of the exhaust's thermal energy doesn't mean you want the exhaust to cool as it exits the turbine.
Bottom line, colder exhaust is slower. If you have a turbo-back exhaust system made out of aluminum, the gas is going to cool and slow down as it heads for the tailpipe. That means the hotter/faster exhaust pulses coming out of the turbo are going to push into the slower moving gases up ahead.
Perhaps the backpressure caused by such a circumstance is negligible, but it's certainly not beneficial.
Old Oct 19, 2006 | 06:47 AM
In what sense?!
Perhaps the backpressure caused by such a circumstance is negligible, but it's certainly not beneficial.</TD></TR></TABLE>
Maybe for a dyno queen. In real life there's this thing called weight, it makes cars slower.
Old Oct 19, 2006 | 07:17 AM
Default Re: (dmoto)
I know you want it to expand as much as possible.. I'm not sure about the cooling part... I'll try to research that tonight... I'm sure tony1 or somebody would know this though.. </TD></TR></TABLE>
thats what i was thinking.
Old Oct 19, 2006 | 07:25 AM
tony1's Avatar
You want the greatest pressure and temperature differential across the turbine. A big aluminum downpipe does that better than a big steel one. Is the power difference even measureable? I don't know, but in theory, the aluminum is better, and it's damn sure lighter.
Old Oct 19, 2006 | 08:15 AM
trickeng's Avatar
Default Re: (tony1)
the cooler the exhaust gases are the easier they are to push out the exhaust. keep in mind when exhaust gases expand they expand in all directions including against the tube walls and back towards the head. this is beneficial for headers, both NA and long tube turbo because each cylinder is helping the next with a properly designed collector of course. but after the turbo you want the least back pressure possible so letting as much heat as possible escape through dissipation is what the aluminum is good for.
at least this is how it was explained to me.
Old Oct 19, 2006 | 10:20 AM
Default Re: (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">the cooler the exhaust gases are the easier they are to push out the exhaust. keep in mind when exhaust gases expand they expand in all directions including against the tube walls and back towards the head. this is beneficial for headers, both NA and long tube turbo because each cylinder is helping the next with a properly designed collector of course. but after the turbo you want the least back pressure possible so letting as much heat as possible escape through dissipation is what the aluminum is good for.
But as already stated the heat/pressure of the exhaust gases is going to make the exhaust expand making it a bigger diameter (as suttle as it may be)
Old Oct 19, 2006 | 05:39 PM
91TSiGuy's Avatar
Some pics from the past weekend of those Mustangs.
Old Oct 19, 2006 | 05:54 PM
PrecisionH23a's Avatar
James/John from Mazworx run a full aluminum exhaust on their EG. It's sexy and I can pick it up with one hand.
I'll most likely be doing a full alum exhaust on my EK as well. The only thing that sucks about Ti is the cost.
Old Oct 19, 2006 | 06:28 PM
NAbox's Avatar
Default Re: Exhaust out of aluminum? (PrecisionH23a)
that rustangs set up is the sickness
Old Oct 19, 2006 | 06:58 PM
srt4thatazz's Avatar
Default Re: Exhaust out of aluminum? (91TSiGuy)
Your car is at JM Fab now isnt it?
Old Oct 19, 2006 | 07:02 PM
91TSiGuy's Avatar
Default Re: Exhaust out of aluminum? (srt4thatazz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srt4thatazz &raquo;</TD></TR><TR><TD CLASS="quote">Your car is at JM Fab now isnt it?</TD></TR></TABLE>
Maybe........
Old Oct 20, 2006 | 12:13 PM
CBURKE's Avatar
Wow guys thanks for all the info, I thought for sure I was going to get a "search you ***"
I know the coast will be high, but hell I am only going to have to do it one time.
Old Oct 21, 2006 | 12:44 PM
GenIIIMrDuece's Avatar
search you ***
Old Oct 21, 2006 | 12:49 PM
CBURKE's Avatar
LOL how did I know that was coming? lol
Old Oct 21, 2006 | 07:13 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
I was thinking about doing an aluminum exh on my hatch for weight reasons. I've got a great link bookmarked on my cpu at work for aluminum tubing. I'll have to post it on Monday.
