safety of drag III turbo on stock b18c5
Old May 4, 2002 | 12:53 PM
blackitrspec's Avatar
New User
Default safety of drag III turbo on stock b18c5
i'm considering it....
can get it for free (as a gift) from someone very close
but i gotta put my engine back to stock cr...
pistons/rings, cams, etc for sale!!!
Old May 4, 2002 | 12:54 PM
Rob :190:'s Avatar
Default Re: safety of drag III turbo on stock b18c5 (blackitrspec)
with correct engine management, it should be ok on low boost (6-7psi i think?)
Old May 4, 2002 | 12:56 PM
New User
Default Re: safety of drag III turbo on stock b18c5 (Brian Spilner 1035)
how's the power?
Old May 4, 2002 | 01:03 PM
Rob :190:'s Avatar
there was a big FI thread a while ago, i think low to mid 200s was with just a bolt on kit. more boost, lowered compression, standalone, over 300 i think one dyno showed. its all about tuning though, if you tune it right, that makes all the difference.
Old May 4, 2002 | 01:06 PM
Willard's Avatar
10-11 psi =
correct management is key
Old May 4, 2002 | 01:09 PM
Rob :190:'s Avatar
Default Re: safety of drag III turbo on stock b18c5 (Willard)
haha 10-11psi.....at that point, drag radials, and a daddy LSD are key
Old May 4, 2002 | 01:17 PM
Willard's Avatar
b18c5 - LSD already...
10-11 psi = roll-ons only... spining 3rd is fun... but not fast.
Old May 4, 2002 | 01:47 PM
ITR #1202's Avatar
can you put the drag lll kit on a type r without lowering the compression
Old May 4, 2002 | 01:50 PM
Back in Black's Avatar
Rather OG
Default Re: safety of drag III turbo on stock b18c5 (ITR #1202)
yes
Old May 4, 2002 | 02:26 PM
Reid's Avatar
Global Moderator
Default Re: safety of drag III turbo on stock b18c5 (Vader in NC)
I wonder how long a B18C (JDM GSR) with 10.6:1 compression will hold up with 10-11 psi with my crappy fuel system (yes I know it's crap but I'm going to use it for now):
Vortech FMU 12:1
stock injectors
stock P72
Apex V-AFC
Walbro 255 lph intank fuel pump
Can you say "kaboom"?
Old May 4, 2002 | 02:39 PM
FAST94GSR's Avatar
New User
Default Re: safety of drag III turbo on stock b18c5 (Reid)
That's too much boost for stock bottom end.. If you want to last a while keep it around 7-8psi. I've seen power around 280 with correct fuel management and tuning.
Even at that the ringlands tends to go.
Old May 4, 2002 | 02:48 PM
Rob :190:'s Avatar
Default Re: safety of drag III turbo on stock b18c5 (FAST94GSR)
so is there such thing as a safe boost on a stock c5? 5psi or something?
rob- who outgrew his turbo wishes.
Old May 4, 2002 | 02:50 PM
FAST94GSR's Avatar
New User
Safe?? hahah no.
Old May 4, 2002 | 02:57 PM
AllMotorITR's Avatar
New User
Just a side note: If you're gonna go turbo, I suggest going with a custom kit, you can put one together with all the parts you want for around the same price of a Drag III kit.
Old May 4, 2002 | 02:58 PM
Rob :190:'s Avatar
Safe?? hahah no.
life is a series of compromises i guess
Old May 4, 2002 | 06:21 PM
Willard's Avatar
light pressure turbo is your friend...
10-11psi all day (12-13psi if needed)... safe tuning and proper temperature levels are all that is needed.
Will
Old May 4, 2002 | 07:27 PM
Zeus's Avatar
Researched the hell out of it cause I'd thought of doing it to mine... With something along the lines of a tuned Hondata, seems 10psi on the OE long block is doable to the tune of around 300whp + or - depending on the skills of the tuner... Seems that using the mechanical fuel enrichment method has dropped stock long block ITRs off like flies at anything above 6-7 psi... and some at less. Damn sure better take it to the dyno/wideband O2 for the latter of the two...
Old May 5, 2002 | 06:50 AM
ITR #1202's Avatar
Default Re: safety of drag III turbo on stock b18c5 (Zeus)
who all on the board has turboed their R?
Old May 5, 2002 | 07:02 AM
H-PIMP's Avatar
Stock cams, pistons and ecu will allow you 6-7 psi safely. Anything above that is asking for trouble. Your high comp pistons and JUN bumpsticks will do nothing for a boosted application.
Old May 6, 2002 | 10:12 AM
ITR #1202's Avatar
Default Re: safety of drag III turbo on stock b18c5 (H-PIMP)
would 8psi be okay to run
Old May 6, 2002 | 10:15 AM
FAST94GSR's Avatar
New User
make sure fuel management is up to snuff. even at that there are no guarantees. I wouldn' tgo any higher than 8 without getting a headgasket to lower compression. A good person to talk to is jinxproof99. he has had a lot of success working with stock internalled motors.
Old May 6, 2002 | 10:31 AM
01ITR#700's Avatar
My boost project is underway..I'll keep you all posted...
M
Old May 6, 2002 | 10:33 AM
adam's Avatar
i run 8 daily, on a hondata system
Old May 6, 2002 | 10:46 AM
RTW DC2R's Avatar
a "safer" way to lower the compression would be pistons. hard parts are better whenever possible. Ive heard that a stock ITR bottom end can handle up to 400hp without much problem. now, how long that will last is another question. if you want to be "safe", rip out the stock ITR bottom end(put it aside because you will be needing it when u blow the motor haha), throw on a 2.0L CRV, work it with low CR pistons and rods, maybe even sleeve it, and boost 20psi and have fun while it lasts. werd.
Old May 6, 2002 | 11:41 AM
FAST94GSR's Avatar
New User
Default Re: safety of drag III turbo on stock b18c5 (RTW DC2)
Where did you "hear" that a stock bottom end can handle 400hp??
FYI the post said "safety of drag 3 turbo on STOCK b18c5"
We all know, at least we should , that to do it right is to build it up, but that's not the question here..
