9904 RPM Over-rev now oil light flashes after hard braking
Old Oct 17, 2006 | 07:55 PM
precisionelite's Avatar
Default 9904 RPM Over-rev now oil light flashes after hard braking
So, I was at the drag strip and went from 3rd to 2nd at redline. My Rev's shot to 9,904. My motor sounds just as it did b/f, but just in case i'm gonna run a leakdown and compression test on it. The funny thing is, whenever I brake hard the oil light flashes contiunously. This only happens when i brake hard, what does this mean? Is my oil pump dying?
Old Oct 17, 2006 | 08:11 PM
M2B4's Avatar
Default Re: 9904 RPM Over-rev now oil light flashes after hard braking (precisionelite)
i dont have an answer for you but how do you know it was 9,904 rpms you have a digital tach? also my bro did this today but wasnt detrimental he did 1st to 2nd to 1st only got up to about 7000 rpms.
Old Oct 17, 2006 | 08:13 PM
WhiteBB2's Avatar
Default Re: 9904 RPM Over-rev now oil light flashes after hard braking (M2B4)
i did it once....scared the **** outta me....no problems though! LUCKY FOR ME!
Old Oct 17, 2006 | 08:14 PM
i have an apexi rev/speed meter, it tells you your max rpm's.
Old Oct 17, 2006 | 08:23 PM
ethereal2pt2's Avatar
why would you do that in the first place?
and the hard braking..
i've had that happen to me before.
maybe you're getting low on pressure?
Rosko's Avatar
what rpm's did you hit in third? i did the same thing in mine about amonth ago and I bet it went to about 13k easy. I bent a bunch of valves, with no real signs of it till a few days after when a valve head popped off and destroyed a piston, block and my head.
If you have a boreoscope then you can look through the plug hole and see if theres any nics in the pistons from the valves hitting.
Old Oct 17, 2006 | 08:39 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by precisionelite &raquo;</TD></TR><TR><TD CLASS="quote">So, I was at the drag strip and went from 3rd to 2nd at redline. My Rev's shot to 9,904. My motor sounds just as it did b/f, but just in case i'm gonna run a leakdown and compression test on it. The funny thing is, whenever I brake hard the oil light flashes contiunously. This only happens when i brake hard, what does this mean? Is my oil pump dying?</TD></TR></TABLE>
it means you should fill your oil up....lol you're probably just low on oil, and it all sloshes the front of the pan when you brake
Old Oct 17, 2006 | 09:20 PM
M@'s Avatar
M@
Default Re: 9904 RPM Over-rev now oil light flashes after hard braking (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">
it means you should fill your oil up....lol you're probably just low on oil, and it all sloshes the front of the pan when you brake</TD></TR></TABLE>
x2
Old Oct 17, 2006 | 09:23 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">it means you should fill your oil up....lol you're probably just low on oil, and it all sloshes the front of the pan when you brake</TD></TR></TABLE>
yea but that light doesnt flash unless the engine is in serious deprivation of oil.
Old Oct 17, 2006 | 10:07 PM
mgags7's Avatar
yea blake it will come on if youre under 6psi of oil pressure
you dont have to be all that low on oil to do that if you hit the brakes hard enough...
Old Oct 17, 2006 | 10:12 PM
plikit's Avatar
Default Re: (bb4ever)
which reminds me i should check my oil...
good luck with gettin her fixed up. ive done the nice 3rd to 2nd... no damage tho...
Old Oct 18, 2006 | 09:36 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (`VTEC`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `VTEC` &raquo;</TD></TR><TR><TD CLASS="quote">why would you do that in the first place?
It happens. You have to shift fast or you'll fall out of VTEC and with the sloppy cable shifter set up its easy to hit 2nd insted of 4th.
Old Oct 18, 2006 | 09:48 AM
k_lude's Avatar
Default Re:
i say go with putting more oil....thats some high revving...i busted my valves and have never seen 9,000...
Old Oct 18, 2006 | 09:55 AM
Turbo Lude SH's Avatar
I did it twice. First time I hit 9900 RPM's and nothing happened. Second time I hit like 9700 and I bent some valves.
Moral of the story: Don't make a habit of it.
Old Oct 18, 2006 | 10:28 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">yea blake it will come on if youre under 6psi of oil pressure
6psi!! That's crazy....I'm at 60-70 psi @ idle on startup and when it warms up it never goes below 20psi @ idle.
Old Oct 18, 2006 | 11:02 AM
Default Re: (Hawkze_2.3)
Thanks guys, put some oil in...problem solved. And yes, I don't intend on making a habit of it
ame28
Dec 8, 2009 05:43 PM
sireg6
Feb 23, 2007 06:49 PM
01BB6
Aug 11, 2005 08:59 AM
danacixem
Aug 10, 2004 01:13 PM
bossman032
17
May 20, 2003 06:30 PM
