will dc2 trailing arms/rear disc brake setup work for a disc conversion?
Old Oct 17, 2006 | 07:38 PM
wfocrx's Avatar
Default will dc2 trailing arms/rear disc brake setup work for a disc conversion?
There is one for sale locally from a 95' integra and was wondering if it would work and what else would I need?
Old Oct 17, 2006 | 07:41 PM
Crx Jimmy's Avatar
Default Re: will dc2 trailing arms/rear disc brake setup work for a disc conversion? (wfocrx)
yes it will work fine, they are the same. the only thing you might have to change is the e brake cables they are longer but if you get creative with the routing they will work
Old Oct 17, 2006 | 08:04 PM
wfocrx's Avatar
cool. can the integra arm/caliper handle a bigger rotor or anything? I know the front can allow a 11" rotor
is the rear rotor the same as a crx si?
Old Oct 17, 2006 | 08:32 PM
wfocrx's Avatar
will the fastbrakes rear upgrade for the dc2 work with this? they sell a kit for $240 that comes with an adaptor to allow a 10.9" rotor and since I will be using an integra caliper it should work, right?
THEhomelessONE
Jul 4, 2019 08:20 AM
Gump
Jul 2, 2016 03:38 PM
DOHCtR-V
14
Aug 13, 2014 12:32 PM
ek4hatch
Jul 9, 2004 09:14 PM
