1991 CRX HF Coolant Leak
Old Oct 17, 2006 | 07:14 PM
murray63's Avatar
Default 1991 CRX HF Coolant Leak
Hi,
I have a coolant leak, would appear to be coming from the EGR valve, blown head gasket?
Old Oct 17, 2006 | 07:19 PM
Tippyman's Avatar
Default Re: 1991 CRX HF Coolant Leak (murray63)
Run a leakdown test. It'll tell ya if ur HG is blown. But yes, most likely HG.
Old Oct 17, 2006 | 07:48 PM
BlueCrxNC's Avatar
There is a coolant passage within 1 inch of the EGR passage on the intake manifold where it bolts up to the head. You may just have a bad intake manifold gasket. (cross fingers unless you want an excuse for a swap )
EDIT:
It's the two circular passageways on the bottom left in this pic
Note: Maybe as simple as one of the coolant hoses next to the EGR leaking (also pictured)
Old Oct 18, 2006 | 02:38 AM
murray63's Avatar
Hi,
Thank you, the picture is great, the source of the leak is the EGR valve not the hose directly underneath.
Leaves me with blown head gasket or intake manifold gasket. The engine has 315K miles, maybe time to let it rest in peace.
Old Oct 18, 2006 | 02:57 AM
BlueCrxNC's Avatar
Well, I only gotr 240,012 miles out of my old D15B6 (89 CRX HF) Threw two rods out the block. Cheap swap in of JDM D15B VTEC cost me 700 shipped to NC from Cali (I did all the work putting it in)
Old Oct 18, 2006 | 06:04 AM
HT Chaplain's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murray63 &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
Leaves me with blown head gasket or intake manifold gasket. The engine has 315K miles, maybe time to let it rest in peace.</TD></TR></TABLE>
315K Dont let her die keep it going and just replace the IM gasket to see if that works
Old Oct 19, 2006 | 05:18 PM
ef 4 door's Avatar
Default Re: 1991 CRX HF Coolant Leak (HT Chaplain)
well it all depends on what you want to do? do you want to fix the problem or go for a swap! also look around the hose next to see if the clamp is tight or it might just be a ripped hose, heck even a bad intake gasket. always double check or "test dont jstu replace!"
smg0248
Jan 15, 2019 08:02 PM
civicguy167
Dec 12, 2012 09:11 PM
Steezer
Nov 3, 2011 03:47 PM
tbuck23
Apr 10, 2007 08:53 PM
Jeffrey9
Nov 27, 2005 12:25 PM
