Finally DYNOED JDM H22 hatch...it's been a long time comming!
Old Oct 17, 2006 | 06:53 PM
NICEHATCH's Avatar
Default Finally DYNOED JDM H22 hatch...it's been a long time comming!
I
Modified by NICEHATCH at 6:24 PM 7/20/2008
Old Oct 17, 2006 | 07:00 PM
fast_honda's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (NICEHATCH)
Nice, I like the fact that you kept the stock pistons, cams, fuel pump, injectors, and made 201whp. That's very impressive. I'll have to write all that down.
Old Oct 17, 2006 | 07:35 PM
MadCityLude
Guest
Posts: n/a
Very nice!
Thats how you do it
Old Oct 17, 2006 | 07:36 PM
M2B4's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (MadCityLude)
that makes me feel good bout my motor going in soon lol good job man
Old Oct 17, 2006 | 07:46 PM
A Blue Lude's Avatar
Nice.
Presumably no PS/BS?
Old Oct 17, 2006 | 08:23 PM
7speed's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (A Blue Lude)
Thats my boy so I can answer for him. No he doesnt have p/s or b/s
Old Oct 17, 2006 | 08:52 PM
snzh22's Avatar
awesome results...
what you u think u would have made with that header and w/o the msd ignition? also theres the perfect example of where the h22 stops making power
Old Oct 17, 2006 | 09:05 PM
98vtec's Avatar
moderator emeritus
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (95hprelude)
did you stop revving at 7000 or what? Kinda weird that the power drops off so soon....
Old Oct 17, 2006 | 09:18 PM
Greg H's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (98vtec)
sweet numbers man! very impressive, good tune
Old Oct 17, 2006 | 11:37 PM
7speed's Avatar
I think its because he has a rev lt set at 7.2
Old Oct 17, 2006 | 11:41 PM
SP GARAGE's Avatar
did you run balancer shafts?
Old Oct 17, 2006 | 11:49 PM
98vtec's Avatar
moderator emeritus
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (7speed)
7400
Old Oct 18, 2006 | 12:09 AM
K-Spec's Avatar
very nice numbers! who tuned it? and what size piping did you go with?
Old Oct 18, 2006 | 02:39 AM
Revi's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (khalal538)
Very nice, shes gonna fly. Cant wait to see my dyno numbers in the future.
Old Oct 18, 2006 | 03:54 AM
kulrevon's Avatar
how long did it take to tune? and where did you have it tuned?
what size exhaust after the an-r?
Old Oct 18, 2006 | 05:22 AM
NICEHATCH's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (kulrevon)
Old Oct 18, 2006 | 05:24 AM
NICEHATCH's Avatar
Default Re: (mixxxwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixxxwell &raquo;</TD></TR><TR><TD CLASS="quote">did you run balancer shafts?</TD></TR></TABLE>
No I had the balancer shafts removed. As well as the EGR Removed and Placed a Block-Off Plate.
Old Oct 18, 2006 | 07:27 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">did you stop revving at 7000 or what? Kinda weird that the power drops off so soon....</TD></TR></TABLE>
Old Oct 18, 2006 | 07:41 AM
spun311's Avatar
Nice numbers. Can't wait to see some track times.
Old Oct 18, 2006 | 08:29 AM
Halo's Avatar
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (spun311)
Noticed you are running a p28..what intake manifold are you using? What is the program on the p28? Nice numbers
Old Oct 18, 2006 | 08:56 AM
98vtec's Avatar
moderator emeritus
Default Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (Halo)
Chrome Tuned P28/vtec crossover at 4800rpm
*Crome
i would guess its the stock manifold with the IAB's disabled or removed.
Old Oct 18, 2006 | 12:14 PM
NICEHATCH's Avatar
Modified by NICEHATCH at 6:25 PM 7/20/2008
Old Oct 18, 2006 | 12:15 PM
NICEHATCH's Avatar
Old Oct 18, 2006 | 01:49 PM
alterdcreations's Avatar
what about the lower plenum?
is it gutted or did you kept the lower manifold stock?
did you cut the butterflies out or just unbolt the indivual plates?
Old Oct 18, 2006 | 02:06 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NICEHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Yep...butterflies are removed however the plate was kept to increase plenum size. </TD></TR></TABLE>
thats what i did. The IAB shaft and all is still in there. Taking the valves out was alot easier than removing everything and welding the holes shut.
Here's my graph. Very similar setup.
My hp doesnt start to drop off til around 7300 and my torque is a slow drop off.
and i just noticed that your numbers arent SAE corrected. I'm not downing your car at all. Your graph looks pretty damn good. Looks like you could make a little more midrange power with some more fine tuning. Its just kinda awkward to me that your power drops off pretty steep after 7000.
Do you happen to have your bin file on hand? I wouldnt mind seeing your map. I'll let you see mine
IM me and we'll trade email addresses.
