Cutting 2.5" Mild Steel Piping. Can I use a Miter Saw?
I have always used a hack saw, but I am tired of doing it that way. I wish I had a band saw laying around.
Can I use this Electric Miter saw to cut the piping. Might have to do it one side at a time, but is it possible? If not that is fine, but I got one back home and thought it might be worth a try.
The metal cutting miter saws have a slow rpm. they only spin at about 1600 rpm on a 12" blade. You can't just put a metal blade in that saw. It will cut aluminum really well with a carbide and a little lube wd40 but not steel and especially not stainless. Your saw probably spins about 3450-3600 rpm way to fast for steel
I use my wood saw all the time!
Best thing to do when cutting stainless, is to PUSH and RELEASE the trigger. Every Second.
This will allow it to slowly cut, yet it wont heat the stainless up, where it will get VERY hard to cut, if you heat it up.
Try it
Use a blade for metal though. Dewalt blade works like a charm.
Try itUse a blade for metal though. Dewalt blade works like a charm.
Yah, I ordered some 2.5' Mild steel piping from Racing Solutions so hopefully this saw will cut it.
Harbor Freight sells a 14" chop saw for $50. Can't beat that. I use mine 2-3 times a weeks for about 7 months. No problems here.
You can use a woodcutting saw, but be careful, they are not meant to cut metal and so they are not really protected from metal shavings very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg »</TD></TR><TR><TD CLASS="quote">
>>><<<</TD></TR></TABLE>
thats the route i am going when i begin fabbing my piping
Be careful with the cheap chopsaws. They usually tweek at their pivot points while cutting causing angled cuts.
I use a wood saw like that i just put in a metal blade... I have cut 4" piping with it lol.... Im going to buy a normal metal saw that goes lower speed. Cause i think it is eating my disc's kinda fast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboc1 »</TD></TR><TR><TD CLASS="quote">the plastic will melt.</TD></TR></TABLE>
I'm surprised it took this many posts for someone to point this out..
yes. we are cheaping out at work too and the same thing happened
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW »</TD></TR><TR><TD CLASS="quote">What plastic? The plastic guard? </TD></TR></TABLE>
The first time I made intercooler piping I used a sawzal. lol
It actually worked really well. I used fresh metal cutting blades and made sure that the guard was pressed up against the piping, then just cut right through it. Only takes a few seconds and makes perfect cuts if you are careful.
The member "TheThiefTheKnife'NTheGun' who is local to me offered to let me use his chop saw that he uses to cut his pipes. So I will most likely take him up on that offer. He's been a great help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TSiGuy »</TD></TR><TR><TD CLASS="quote">Be careful with the cheap chopsaws. They usually tweek at their pivot points while cutting causing angled cuts.</TD></TR></TABLE>
Yup, the thrill of owning a chopsaw wore off after the first cut
When I have to use it I don't apply force on the handel but on the metal casing over the blade, helps push it down and not out.
BlueShadow
Welding / Fabrication
Jun 11, 2005 09:32 PM
