Turn light weird problem.
Old Oct 17, 2006 | 04:40 PM
Metal Typhoon's Avatar
Default Turn light weird problem.
I was coming back home yesterday after college when i turn my left turn signal light on and i notice that it blinked faster than before... laer at the same day i went to check it out... so this is what it's doing.
turning right :
corner light doesnt light up
passanger marker lights up
so does the passanger rear light go on...
turning left :
corner lightS go on.. yes both of them...
driver marker light goes on
so does the driver rear light.
!!!!!!!!! i dont even know what to do...
all the light do work... and this started out of nowhere..
any thoughts !? thank you in advance
Old Oct 17, 2006 | 05:00 PM
b18c4g's Avatar
Default Re: Turn light weird problem. (Metal Typhoon)
sounds like you got a bulb blown out. check your bulbs and make sure that they are all working. if so, you may have a shorted bulb or possibly a flasher that needs to be replaced.
Old Oct 17, 2006 | 05:14 PM
Default Re: Turn light weird problem. (b18c4g)
yes all bulbs are working .. if i just turn on the hazard lights.. they all blink normally... just to make sure i put new bulbs on my marker. If the flasher wasnt working right should they work normally when only the hazard is on ?
invader_zim
Mar 28, 2012 09:57 PM
rayccfhk
Jan 17, 2008 01:28 PM
phoshizzle88
Sep 16, 2007 05:59 PM
integrx
Jan 27, 2004 03:12 AM
niteboyzzz
Oct 4, 2002 11:24 PM
