"Frank" - b20 block & b16 header
Old Oct 17, 2006 | 03:08 PM
Edu VTi's Avatar
Default "Frank" - b20 block & b16 header
Hi, does anyone did this swap? I want to know what should I do to put a b20 to run with the b16 dohc header.
I have buddy club spec 3+ and I'm reving 9500. Does the stock b20 work with this?
Thanks
Old Oct 17, 2006 | 07:40 PM
dpaton's Avatar
Default Re: "Frank" - b20 block & b16 header (Edu VTi)
Stock B20 won't rev to anywhere near 9500 without turning into smoking lump of metal. Sleeve it and get a killer block girdle, then maybe you can make it to 9k. Sleeve a GSR block to 84mm if you really want to rev that high.
Old Oct 18, 2006 | 12:04 PM
HiProfile's Avatar
Default Re: "Frank" - b20 block & b16 header (dpaton)
I'm assuming you mean b20 block with a b16 HEAD, not headER. The B20 would be good for 8000 at the most. A local guy who builds nothing but Hondas every day got his b20/vtec to last a couple months, revving it to 8500-9000 every day. When it blew, it took out the whole block and a few valves.
In less words, no, it won't work like you think.
adonis2oo2
30
Jan 4, 2007 10:31 PM
turbo Si
Nov 11, 2005 06:36 PM
jt-sport
Aug 11, 2005 06:41 PM
Jaydo
Jul 14, 2003 01:14 PM
