Need wiring help
I'm installing an Apexi' S-AFC II and Buddy Club V-Con VTEC controller, and i'm having trouble with the wiring. I have the electrical schematics, and ECU pinouts, but I'm unsure about the placement of the wires. These are the wires,
Ignition Power
Primary ECU Ground
RPM Signal (I don't know what sensor it comes from)
Map sensor
Throttle Position Sensor
Knock Sensor
Also V-Con only controls VTEC changeover, and can only hook to one of the VTEC wires. So is it the Solenoid or the Pressure switch. Most of the signal and sensors i'm already fimiliar with, but i'm self taught as far as working on cars, so any info on this will be very helpful.
Ignition Power
Primary ECU Ground
Map sensor
Knock Sensor
slimjim07
Apr 26, 2013 05:21 PM
WickedWerx
Oct 24, 2004 06:15 PM
