LS VTEC TURBO OIL LINE AN FITTINGS
Old Oct 17, 2006 | 11:35 AM
allanonjj's Avatar
Default LS VTEC TURBO OIL LINE AN FITTINGS
If anyone could help me out by telling me what all I need to run an oversized oil line to the head using AN fittings Id really appreciate it....Or even a number to call someone and ask. Ive never done this before so I dont really know where to start.
I JUST did a rebuild on this motor and It looked like the bearings were a little oil starved at one time or another. I never had a bottom end knock but I did have a LOT of slap from the pistons. I feel like the motor wore out pre-maturely so It seems to me like better/more oil/oil pressure couldnt hurt. Any advice will be greatly appreciated
Old Oct 17, 2006 | 11:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: LS VTEC TURBO OIL LINE AN FITTINGS (allanonjj)
an oversized feed line to the head wont help the oil pressure at the mains and rods.
if anything the larger line will just dop oil pressure since it will take more volume to fill the line.
the typical sized feed to the head is a 6-an line, that is enough
Old Oct 17, 2006 | 12:54 PM
authority1's Avatar
I suggest grabing a prodrive oil pump gear and an oil filter adapter (greddy)
Old Oct 17, 2006 | 01:34 PM
inspyral's Avatar
Are you running a VTEC oil pump?
Old Oct 17, 2006 | 02:15 PM
allanonjj's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Are you running a VTEC oil pump?</TD></TR></TABLE>
Yes<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">an oversized feed line to the head wont help the oil pressure at the mains and rods.
the typical sized feed to the head is a 6-an line, that is enough</TD></TR></TABLE>
I know that, I was hoping that it would help the oil flow in the head. Am I wrong?
This last build was the first one I tackled by myself if that gives you an idea to my experience level. Ive built a many ATV and dirtbike engine and done most of my Civic's engine work myself(with guidance) so Id say that ive got a lil mechanical sense..... just not enough to know the answer to this question,... Just a hypothesis I guess............
Old Oct 17, 2006 | 02:21 PM
allanonjj's Avatar
Default Re: LS VTEC TURBO OIL LINE AN FITTINGS (authority1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by authority1 &raquo;</TD></TR><TR><TD CLASS="quote">I suggest grabing a prodrive oil pump gear and an oil filter adapter (greddy)</TD></TR></TABLE>
Wanna steer me in the right direction? Who sells? H-T?
Old Oct 17, 2006 | 06:26 PM
black98gsr-t's Avatar
-6 is usually the norm but u can use -4 .. might help keep more oil and oil pressure to the bearing...
Old Oct 17, 2006 | 09:59 PM
Dunc's Avatar
BCICAN
Default Re: LS VTEC TURBO OIL LINE AN FITTINGS (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">-6 is usually the norm</TD></TR></TABLE>
-6 is what comes in the golden eagle conversion kit. For myself, I'm using a -8.
Old Oct 17, 2006 | 10:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (allanonjj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj &raquo;</TD></TR><TR><TD CLASS="quote">Yes
This last build was the first one I tackled by myself if that gives you an idea to my experience level. Ive built a many ATV and dirtbike engine and done most of my Civic's engine work myself(with guidance) so Id say that ive got a lil mechanical sense..... just not enough to know the answer to this question,... Just a hypothesis I guess............</TD></TR></TABLE>
well, youll get more flow but not pressure.
but if the problem is in the bottom end then you need to look at keeping pressure up/having more of it.
shim the spring on the pump, that will raise the oil pressure, run a slightly heavier oil.
the prodrive gear is really pointless. does nothing for pressure or flow, just a little bit more assurance against grenading an oil pump gear but thats what fluidamprs are for
Old Oct 19, 2006 | 05:45 AM
allanonjj's Avatar
Default Re: (wantboost)
That makes sense,... WHat size shim should I use?
Anybody wanna recommend somewhere to get -6 the oil line? I dont wanna get ripped if at all possible.
Old Oct 19, 2006 | 10:00 AM
Dunc's Avatar
BCICAN
http://www.summitracing.com they are very easy to make your own.
Old Oct 19, 2006 | 11:18 AM
allanonjj's Avatar
Default Re: (AF-P Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">http://www.summitracing.com they are very easy to make your own. </TD></TR></TABLE>
See thats what Im talkin about. I dont wanna sound like a little baby *** but I dont know what to order. They dont sell a kit or something? If I had to tell the salesman all the fittings I would need, I couldnt because Im not at all familiar with them.
-6 is what comes in the golden eagle conversion kit. For myself, I'm using a -8. </TD></TR></TABLE>
U got a website for them?
1990hf
Jan 13, 2009 12:55 PM
laos619
Apr 2, 2007 11:28 AM
killa_lude
Aug 21, 2004 11:44 AM
DR. ON POINT
Sep 19, 2002 09:31 AM
lswithvtec
Nov 27, 2001 11:06 AM
