OBD1 in OBD2 car - How to check code?
Old Oct 17, 2006 | 08:09 AM
Tonyl507's Avatar
Default OBD1 in OBD2 car - How to check code?
Like title says, Ive searched, but ive come up two things...
"jump D4 to a ground and see the light flash" - What wires D4? which connector does this mean? ON the ecu? BY the ecu?
also, people say something about grounding a wire on the pass. side shock tower under the hood- which wires are theses?
My car is a '97 integra with p72 w/ a OBD2a-OBD1 jumper to a OBD1 p72 ecu.
I get a code right at startup and cant figure out how to check it....
EDIT: Heres what Im dealing with:
2ecus, both p72, OBD1 on top, OBD2a on bottom:
Heres what under teh kick panal looks like, and the jumper harness. (The extra wires are for vtec - it used to be an LS)
And heres the whole thing:
Which wires? How can I check a code?
[Heres the whole problem... When I run OBD2a - its fine for around a day, then I get 2 codes:
P0420 - Catalyst manfuntion
P0453 - EVAP system pressure high
SO.... i figure I switch to OBD1 b/c obd1 isn't as picky about that kinda emmision crap. I buy the harness- as far as i can tell its wired right - and I turn on teh car and get a code right away - Im trying to figure out what code it's throwin... ]
EDIT: Okay found a nice link - anserewed my oun question. Well anyway hope this link helps other people:
http://technet.ff-squad.com/how-to/celcheck/
EDIT #2: By the way, the code I was throwing when swtiching from ODB2-1 was b/c the IAB valve on the GSR manifold is wired differntly from OBD2 to OBD1. OBD2 requires a negavitve ground, while OBD1 rquires a 12v source. I think thats right, if that dosent work, reverse it
Modified by Tonyl507 at 9:38 AM 10/17/2006
Modified by Tonyl507 at 10:44 AM 10/17/2006
Modified by Tonyl507 at 10:11 AM 11/2/2006
Old Oct 26, 2006 | 11:44 PM
Kangolbrand's Avatar
BUMP, this should be up top, nice link... very detailed. Thanks again!... BUMP~!!!!!1
Old Oct 27, 2006 | 02:03 AM
charlee's Avatar
Default Re: (Kangolbrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">BUMP, this should be up top, nice link... very detailed. Thanks again!... BUMP~!!!!!1</TD></TR></TABLE>
x2
2Point3
May 20, 2009 05:18 PM
ViXoN Hatch94
Jun 21, 2006 12:43 PM
sikcrx80
May 21, 2006 01:56 PM
mouse
Jan 30, 2006 06:57 AM
stevieteg
May 17, 2004 11:35 AM
