$$$ Rotors rotors rotors brakes brakes brakes $$$
So my rotors are unevenly worn. Just running a finger over them...it's obvious. Going to go with Brembo blanks up front and searching for ones for the back. Online I haven't had much luck finding brembo rears. Do they even make them or should I just get basic autozone/napa specials for the rear?
Also I've been hearing that you should always put on new pads with rotors which is kind of a shame because I just replaced my pads a few months ago. BUT on the bright side my EBC's have been horrible with brake dust. Clean my rims and a week later they are coated again. Anyone share in the same problem and recommend a cleaner pad? My car is just for daily driving...no racing..minimal back road bombing...
Thanks in advance.
Thanks in advance.
most performance brake pads will dust. maybe you should try waxing your rims (helps keep dust off) or stick with oem / autozone cheap pads. don't dust as much and you don't go anything above normal driving anyways.
also, autozone rotors are just as good as brembo
^^^^^ agreed to the above I think it is eather brembo or power slot that use raybestos rotors to slot and cross drill and they are autozone brand
I just did my brakes also recently. Search and searched. I went with autozone's duralast rotors and pads. The setup is doing good so far. You should also get a 2yr warranty on the rotors and life time on the pads. So before the 2 years are up, get em really hot and spray em down with ice cold water.
