Oil sandwitch plate question....?
Old Oct 16, 2006 | 10:24 PM
spriggan's Avatar
Default Oil sandwitch plate question....?
I'm trying to find a sandwitch plate to use for my oil cooler setup?
Just trying to find feedback upon these items.
If it comes down to it, I'll just pick up a greddy oil cooler kit instead just to be safe.
Has one used this....?
http://cgi.ebay.com/ebaymotors...ZWDVW
OR
http://store.summitracing.com/...w=sku
Old Oct 17, 2006 | 12:21 AM
donkiman's Avatar
Default Re: Oil sandwitch plate question....? (spriggan)
I used one made by Blitz. kinda looked like the second one. Its a pretty simple product, both should work fine.
Old Oct 17, 2006 | 04:43 AM
mike1114's Avatar
Default Re: Oil sandwitch plate question....? (donkiman)
go with the second one. I wish I did.
I bought the first one and it does not fit well on the back of the block. The two 1/8 npt ports would hit my waterpipe and cause a small coolant leak when I tightened the sandwhich plate down. It would not physically fit any other direction.
There just isn't enough room to use the first one well. maybe if you have the OEM oil cooler on the back of the block it would work better but I don't.
Some good words of advice, make sure you buy 45 or 90 degree screw in NON swivel fittings to come out of the sandwhich adapter to attach hoses to.
Modified by mike1114 at 4:24 PM 10/17/2006
Old Oct 17, 2006 | 07:00 AM
Got_soy's Avatar
i would stay away from the ebay one, thier oil sandwich plates like to leak oil.
Old Oct 17, 2006 | 10:10 AM
rtype11's Avatar
Default Re: Oil sandwitch plate question....? (Got_soy)
I ran into problems with both styles, the second transdapt one looks better than the one i had though the threaded ports are more flush than on my old one that i need to clearance alot to get it close to fitting, gave up and went with transdapt spin on adapter to fliter relocation using cheap mustang filters. buy one from golden eagle i am sure they figured out the clearnace issues with honda blocks.
Old Oct 17, 2006 | 10:49 AM
iBrandon's Avatar
Default Re: Oil sandwitch plate question....? (rtype11)
Golden Eagle!!
Old Oct 17, 2006 | 02:55 PM
Autoworks's Avatar
Default Re: Oil sandwitch plate question....? (iBrandon)
I use the ones in the 2nd pic all the time. Work great
Just get the earls 3/8 plug for one side and the 3/8 male outside/ 1/8 female inside adaptor for the other side. Along witha 1/8 to 18 male adaptor
Old Oct 17, 2006 | 04:36 PM
platinum00's Avatar
i currently use the 1st one with no issues. it was a little ruff to get it installed over the other units, but it works perfectly fine.
i have a oil cooler, oil temp and oil feed hooked up to the unit
platinum.
Old Oct 18, 2006 | 04:40 AM
mike1114's Avatar
Default Re: Oil sandwitch plate question....? (platinum00)
platinum.....throw up some pics, I want to see how you got it to work.
Do you have an OEM oil cooler already?
Old Oct 18, 2006 | 09:20 AM
platinum00's Avatar
Default Re: Oil sandwitch plate question....? (mike1114)
No OEM cooler.
The lines run up the back of the block and then down the front to the cooler. I ran it this way so the oil heats up a bit quicker from the engine temps.
Im running a D-Series so there might be more room than a B-series or something.
You can see the larger lines to the right of the oil feed line right above the air filter.
platinum.
Old Oct 18, 2006 | 09:43 AM
mike1114's Avatar
No pic should = BAN!!
j/k..must be more room on the back of the D.
Old Oct 18, 2006 | 09:50 AM
agrn93ls's Avatar
Golden Eagle
Old Oct 18, 2006 | 11:24 AM
95dc2teg's Avatar
Default Re: Oil sandwitch plate question....? (agrn93ls)
I got the one that looks like the second picture from ebay. It fits perfect with absolutely no leaks. I think its a much better solution that using the t-fitting on the back of the block.
heres the one i got FTW
Old Oct 18, 2006 | 11:31 AM
Speed Infliction's Avatar
Default Re: Oil sandwitch plate question....? (95dc2teg)
^ I have that one too. that is a Function 7.
Old Oct 18, 2006 | 05:19 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">No pic should = BAN!!
j/k..must be more room on the back of the D.</TD></TR></TABLE>
you should see a pic, did i post it wrong? or did you mean of the adapter.
platinum.
Old Oct 18, 2006 | 05:33 PM
ImportechPerformance's Avatar
This looks like a very nice kit but kinda pricey 300.00
Oil cooler + Oil filter relocation
http://cgi.ebay.com/ebaymotors...idget
pic:
coneheadsracing's Avatar
I think he wants to see one of the adapter.
I run the second one, no issues for me, but it too was on a D. I used 45's and swivel joints, i think they are called. Makes life easier.
Old Oct 18, 2006 | 07:03 PM
agrn93ls's Avatar
Default Re: Oil sandwitch plate question....? (coneheadsracing)
i used golden eagle no fit/function issues and no freakin adapter here adapter there crap. the less fittings the less likelyhood of problems to me. i used it for LS/VTEC application and turbo, couldnt ask for a better product for my application.
firewall
Dec 10, 2017 07:14 PM
Agito
13
Jan 18, 2008 04:34 PM
spriggan
Oct 18, 2006 08:04 PM
kuja
Jun 28, 2005 09:30 PM
JDMproject17
11
Feb 15, 2004 08:42 PM
