compression test on gsr motor help!!!!
Old Oct 16, 2006 | 08:35 PM
bustdgst's Avatar
Default compression test on gsr motor help!!!!
i just did a compression test on my motor(gsr block/b16 head) before i installed a turbo and here is how cylinder reads (#1 225) (#2 220) (#3 185) (#4 220). I know there is a huge difference on the #3 cylinder which would explain why when i took the plugs out all of them where fine except for #3 which looked alot darker than the others, almost fouled out. What would cause the plug to do that along with what would cause cylinder pressure drop?? any ideas????
Old Oct 17, 2006 | 05:55 AM
bustdgst's Avatar
i know someones gotta have some kind of idea about this!!
Old Oct 17, 2006 | 08:57 AM
drift4jesus's Avatar
Default Re: (bustdgst)
Do a leak down test as well. This will tell you better if its your rings or valve seats.
Old Oct 17, 2006 | 09:30 AM
mmuller's Avatar
Mad Scientist
Default Re: (drift4jesus)
you say the plug looks fouled? oil fouled?
its prolly the rings
Modified by mmuller at 1:48 AM 10/19/2006
Old Oct 17, 2006 | 03:59 PM
bustdgst's Avatar
yeah...its got a funky idle to it too!
Old Oct 17, 2006 | 05:20 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: compression test on gsr motor help!!!! (bustdgst)
Bent or improperly adjusted valves can cause low compression. Did you add oil to the cylinders and redo the compression check? Thus will test the rings for leaks.
Old Oct 18, 2006 | 09:41 PM
boost'd_crx's Avatar
had the same problem, do a leakdown test. turned out to be a bent valve.
Old Oct 19, 2006 | 07:20 AM
teler86's Avatar
Default Re: compression test on gsr motor help!!!! (boost'd_crx)
put a table spoon of oil into cylinder #3 through the spark plug hole, then do a compression test again on cylinder #3 if compression goes up to normal it is piston rings, if compression still stays low, it is somthing with the valvetrain/head.
Old Oct 19, 2006 | 05:49 PM
maxpsi's Avatar
Default Re: compression test on gsr motor help!!!! (teler86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teler86 &raquo;</TD></TR><TR><TD CLASS="quote">put a table spoon of oil into cylinder #3 through the spark plug hole, then do a compression test again on cylinder #3 if compression goes up to normal it is piston rings, if compression still stays low, it is somthing with the valvetrain/head.</TD></TR></TABLE>
Good ole wet compression test. Works everytime. Helped me narrows things down to piston rings on my old motor.
negusjuda
Aug 8, 2011 02:44 PM
sinister357
Aug 25, 2007 10:05 PM
Sport_Injected
Aug 16, 2004 09:06 PM
RedRacerCivic
11
May 22, 2003 10:29 AM
lazyguy
May 5, 2002 01:36 PM
