how to put an integra dash in a crx?
Old Oct 16, 2006 | 08:31 PM
elwrestler03's Avatar
Default how to put an integra dash in a crx?
So I have heard of people putting acura integra dash into a crx. I was wondering If theres a write up on this or if anyone can tell me how its done. Thanks I am new to this forum as you can tell by the huge newb sign but any help would be greatly appriciated.
Old Oct 16, 2006 | 09:21 PM
Magick211's Avatar
Default Re: how to put an integra dash in a crx? (elwrestler03)
There are a few threads floating around here with a lil information on it. Dash is gonna require a bit of trimming and custom mounts will have to be made. also you cannot use your door panels with the setup. Try to search for the few topics floating around
Old Oct 16, 2006 | 10:02 PM
so I would have to get the integra door panels as well? And were should I search? Should I look in the civic & crx faq version 2.0?
Old Oct 16, 2006 | 10:17 PM
gsrpedro's Avatar
you want the hole dash or just the cluster??
Old Oct 16, 2006 | 10:19 PM
Magick211's Avatar
Default Re: how to put an integra dash in a crx? (gsrpedro)
https://honda-tech.com/zerothread?id=438732 Here this might help you a lil.
Old Oct 17, 2006 | 07:49 AM
Andy R's Avatar
Default Re: how to put an integra dash in a crx? (Magick211)
Here are a few pics of what I did. Its secured in the top 2 corners and behind the clock location. Then I built some custom supports that will attach to the roll cage at the knee bar location. Had to trim the back side of the dash where the defrost ducts ran on the sides. This isn't a functional dash, but visual for a road racing track car. Picked up a tan dash with cluster for $20, spent $10 on black vinyl spray, spent about an hour to rewire the cluster and done. Aluminum peices were fabbed up to fill the clock, air bag, and radio/heating/vent opening. I don't have recent pics uploaded yet, but additional gauges and switches are no installed.
Old Oct 17, 2006 | 10:05 PM
That looks good. So did you have to do anything to the steering column at all? I want to do this because I like my crx alot and want to keep it instead of spending money on a newer car. I want to make it look newer aged inside instead of 80's. I wonder what I could do about the doors.
Old Oct 17, 2006 | 10:07 PM
That push botton is awsome too
Old Oct 18, 2006 | 05:39 AM
Andy R's Avatar
Default Re: (elwrestler03)
The steering column was not modified and as far as the doors panels I have no idea how they will look/fit with the stock door panels since i've just got a sheet of aluminum riveted in place.
Old Oct 18, 2006 | 09:11 AM
crx2nr822's Avatar
Default Re: (Andy R)
Search man! The thread that Magick211 posted was like 5 spots ahead of yours......and that should have most of the information you need.
Old Jul 25, 2020 | 05:47 AM
Nuvuku's Avatar
Just wondering why I can't see the images in this thread... I rly wanna do this swap but can't see anything. Hopefully it's bcuz I'm a new member (i just joined to specifically view these image lol)
Old Jul 26, 2020 | 05:28 AM
EE2bitsk's Avatar
because the thread is 14 years old.
cjonescrx
14
Jan 8, 2010 02:06 PM
dracocrx
Jan 28, 2009 07:30 PM
ef8beast
Sep 2, 2006 12:47 PM
flatblackhatch
Dec 30, 2005 10:12 AM
lionel
18
Dec 5, 2005 04:52 PM
