what wheels do i need to buy size for these rims
Old Oct 16, 2006 | 08:07 PM
madlion's Avatar
Default what wheels do i need to buy size for these rims
what size tires do i need?
Bolt Pattern: 4x100/114.3
Off Set: +42mm
i have a 2000 civic si
weight 13lbs
Old Oct 16, 2006 | 08:32 PM
madlion's Avatar
Default Re: what wheels do i need to buy size for these rims (madlion)
wow i just reread that topic sorry guys thats horrible.
Old Oct 16, 2006 | 08:46 PM
xNOBOOSTx's Avatar
i would say 205 or 215, 45 or 50, 16
Old Oct 16, 2006 | 09:15 PM
madlion's Avatar
Default Re: (xNOBOOSTx)
what does each measurement mean
Old Oct 16, 2006 | 09:17 PM
xNOBOOSTx's Avatar
the first is the width. the second is the sidewall. and the third is the wheel size.
Old Oct 16, 2006 | 09:22 PM
madlion's Avatar
Default Re: (madlion)
i have the eibach and agx set up if that helps? wouldnt i need a specific width how can it be 205 or 215?
madlion's Avatar
shouldnt it be the width of the actual rim?
Old Oct 16, 2006 | 10:29 PM
vtecsi00's Avatar
you need a 205/45r16 for your wheel size or a 215/45r16
195/55r15 205/45r16 215/45r16
sidewall height: 4.22 3.63 3.81
section width: 7.68 8.07 8.46
overall diameter: 23.44 23.26 23.62
Old Oct 18, 2006 | 08:13 AM
DaveSi677's Avatar
Default Re: (vtecsi00)
you need the correct size for the car not the rim. 205-45-16 or 215-45-15. I would go with the 205 as they are a closer to the stock diameter so it will keep your speedometer accurate.
NateB
May 12, 2011 03:47 PM
precise
Dec 30, 2009 02:08 PM
1995Civiccx
Mar 17, 2007 12:46 PM
RacingShoeBox
Aug 17, 2005 12:08 PM
CoolKat
Jan 23, 2003 08:58 PM
