wiring in vtec
i bought a vtec engine and i used to have a non vtec. how do i wire that in with the ecu. also if i buy a ex harness do i have to wrie in vtec or can i just have it work. cause that would be awesome. the car is a 95 accord lx. with a f22b1 replacement
you will need to run wires for vtec. you cant swap out harnesses and have it function correctly without changing both the engine harness and the cabin harness. but its simple run the two signal wires to the corresponing pinout locations on the ecu plugs...and you will need a vtec ecu - which i happen to have on that im selling!
well you see because from the shock tower (where the engine harness connects to) to the ecu will not have the 2 wires needed for vtec. and if youve ever taken a car/cabin harness out you would see that it is all integrated into one piece. so you would have to remove/ replace the whole thing...
Vtec is A4 and Vtec pressure switch is D6. The black wire in the vtec pressure switch goes to ground.
and if you gotta swap pins a6 and a11 cuz the POA ecu has the o2 and egr swapped if your using that ecu
thanks i appreciate it. i got a ex ecu i dont remember the code i think it is pob i have poa too if anyone needs one i wnat to sell it for like $40. if anyone wants it send me the zip code city state and address and i will check on shipping for you
yeah i have both ecus though so i know what one is vtec because taht one looks like **** but the one im selling is in great condition so i can always look at it before i put it in the car
Presscott707
Oct 12, 2017 09:10 PM
to HondaPartsHero! I actually bought an IAB and Knock Sensor wiring harness from him and they worked out great. Made wiring a breeze ...
