Problem with my 89 crx dx
Old Oct 16, 2006 | 06:23 PM
crxben's Avatar
Default Problem with my 89 crx dx
Ok my 89 dx has a few problems with it. The motor I have in the car is a jdm d15b. First for some reason i keep throwing a vss code (17) i dont really know why beauce everything looks to be ok with with wiring. Second, when im at a stop my car will rapidly go from 1 thou rpms to almost zero and back and forth. It sounds like it is going to die out. Any help with these problems would be great, thanks.
Old Oct 16, 2006 | 06:24 PM
jdm_ef9_b16's Avatar
with the vss code, does your speedometer work? with the idle, check you iacv .
Old Oct 16, 2006 | 06:26 PM
crxben's Avatar
Default Re: (jdm_ef9_b16)
The speedometer works fine, even with the cel on. Just not sure why it keeps throwing the code.
Old Oct 16, 2006 | 06:32 PM
TEXREX88's Avatar
Default Re: (crxben)
Have you ever changed the main relay? Seems to fix a lot of random problems.....
Old Oct 16, 2006 | 07:07 PM
crxben's Avatar
Default Re: (TEXREX88)
No never thought that would cause any of my problems.
Old Oct 16, 2006 | 07:23 PM
crxben's Avatar
Does anyone think it may be the plug wires, spark plugs or distributer causing the weird idle jumping.
Old Oct 16, 2006 | 11:21 PM
ekul101's Avatar
yo i had the exact same problem. make sure ur running the right ecu for ur car, cuz turns out i was a running an integra ecu when i needed crx. The integras run an electrical speed sensor, whereas the crx runs a mechanical so the CEL would always be on. i changed the ecus and bingo no more vss code
Old Oct 17, 2006 | 04:15 AM
crxben's Avatar
Default Re: (ekul101)
Yeah im running the rite ecu, so thats not the prob. the vss only comes on then i break really hard or hit a big bump.
Old Oct 17, 2006 | 08:37 AM
crxben's Avatar
Can any one else pinpoint what it might be????
Old Oct 17, 2006 | 10:14 AM
Tippyman's Avatar
If you are still using a mechanical VSS, make sure that it is in all the way and clipped in with the locking clip.
Old Oct 17, 2006 | 11:11 AM
NikoZai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXREX88 &raquo;</TD></TR><TR><TD CLASS="quote">Have you ever changed the main relay? Seems to fix a lot of random problems.....</TD></TR></TABLE>
nooooo. why do people hate the main relay so much.
VSS probably isn't getting a signal from the dash to the ECU. There's a wire that runs between. Either your ECU Jumper has that wire mis-pinned or broken, or it's disconnected somewhere between your guage cluster and the ECU. You'll need to check this with a volt meter for continuity.
As for the "hunting" (idle surge) Try adjusting your idle screw. Then clean your IACV.
If you don't know what I'm talking about download the service manual and go through the troubleshooting steps like it says:
http://www.norcalcrx.org/library/ (workshop manual link on the right)
Old Oct 17, 2006 | 07:29 PM
crxben's Avatar
Default Re: (NikoZai)
Thanks for everyones input.
civicb1812345
17
Aug 21, 2013 09:37 PM
SIR_APPROVED
16
Nov 25, 2010 01:01 PM
crex23
May 3, 2005 11:01 PM
crex23
Apr 10, 2005 11:00 PM
RotiEatter
Jun 22, 2003 08:35 PM
