Fuel problem with crx si
Old Oct 16, 2006 | 05:25 PM
AznPrideYo's Avatar
Default Fuel problem with crx si
The 1990 crx si isn't getting fuel and I could use a little help.
Things I have checked and tried:
-I am getting fuel pressure (shot 2 injectors out of the rail when I was checking to see if the injectors were spraying lol)
- The injectors are not spraying when hooked up to the injector clips but they do spray when wired to a battery
- I am getting .5 V in each injector clip when trying to start ( not sure if this is the right voltage)
Things I have swapped with working parts:
- main relay
-injectors
-resistor box
-FPR
Please don't assume anything because I just bought the car and know nothing of the previous owner.
Thanks,
Greg
Old Oct 16, 2006 | 05:48 PM
jdm_ef9_b16's Avatar
check the main relay under your dash on the side, the black box looking relay. try knocking on it with a screw driver and see what it does, or replace it
Old Oct 16, 2006 | 05:50 PM
AznPrideYo's Avatar
Default Re: (jdm_ef9_b16)
swapped the main relay + did voltage check
Old Oct 16, 2006 | 06:07 PM
Cornwhiskey's Avatar
Default Re: (AznPrideYo)
check ecu fuse under the hood
Old Oct 16, 2006 | 06:08 PM
check your resistor box, fuel filter, check all your wiring, other than what uve stated, i dont know. sorry dude
Old Oct 18, 2006 | 12:30 PM
AznPrideYo's Avatar
bump, noone ever had this problem?
rickscrx
19
Jan 21, 2011 12:42 PM
winddraft
Mar 15, 2010 02:30 PM
93baggedcivic
Jun 20, 2007 12:51 AM
FastAsleep
17
Aug 28, 2006 04:40 PM
