Why would cyl 2 be running lean?
Old Oct 16, 2006 | 04:34 PM
SimplyTron's Avatar
Default Why would cyl 2 be running lean?
I have a b16a obd0 with a PR3 chipped with BRE. I am running the stock fuel/ignition maps, with just modifed vtec and launch control. The other day I started my car and whenever I gave it more than half throttle just reving it and you studder and misfire at low rpms. I pulled my plugs and 1,3 and 4 were all gray and a little bit of brown. Number 2 was all silver/white. My ring is getting worse in that cyl and now I know why. I changed out the injector with a known good one. I checked voltage from the injector plug and its getting voltage. I have to wait for the plugs to change more but I can already see a slight difference in the color between the rest of the cylinders. What else could be making one cylinder run lean when the others are running fine?
Old Oct 17, 2006 | 12:12 PM
SimplyTron's Avatar
Compression results:
190 175 200 196
After adding a couple drops of oil to eacg cylinder:
195 185 200 196
Old Oct 17, 2006 | 05:23 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (SimplyTron)
The compression test indicates a potentiall bad ring. Go get a leak down test to confirm it.
dochtwincam
Jun 18, 2017 08:53 PM
WhiteOnRice
May 19, 2008 08:06 PM
95greenlude
Nov 3, 2007 04:21 PM
garados
Dec 7, 2003 02:41 PM
crashoveride
Oct 5, 2003 10:00 AM
