Almost killed my partner
Old Oct 16, 2006 | 03:34 PM
josh green's Avatar
Default Almost killed my partner
We sunday we decided we were going to the track after I got off work. So we loaded up and got to the track a little later than we wanted but oh well. Well the girl tells is they are closeing early at 6. We were kinda pissed b/c they were going to charge up full price and we had roughly an hour to get everything unloaded setup and warmed up. So we paid after driving an hour there. Well my partner went to go get race gas b/c the pump were empty and they had it in the tower. So i was putting the slicks on and putting ice in he intercooler and basically speeding up the process so he can hop in a go. Well in the process of putting the freshly painted wheels on I put them on wrong. Thinking that they only fit through 1 set of holes and never having the problem before I thought nothing of it. The lugs torqued down fine and everything. Well after coming back from his first and only pass in the car his brakes went out at 130+mph. He said he hit the brakes and they worked fine and then about an 1/8 mile later there was no pedal. So he is okay and gets back to the pit and he tells me what happened and I look down and am like HOLY expletive and I point out the wheel studs. The wheels still roll straight and everything seems fine having not yet taken it apart b/c we are waiting on studs and lugs. But I felt so bad, I mean his wheel or some **** could have come off at 130+ and he could have died. I have definitely learned to pay more attention. I always say "why get in a hurry, you only get disappointed." Front shocks were also blown and did some carving on the slicks. Good thing they weren't new. So no matter how big of a hurry always pay close attention.
I dont know why we tow it with regular wheels on it and change to the slicks, it just takes more time.
Pics.
Old Oct 16, 2006 | 03:39 PM
aquito's Avatar
dawm man that sucks...good thing ur friend is ok....and pay more attention next time..late
Old Oct 16, 2006 | 03:56 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (aquito)
I would have fired you if you would have done that to me.
Old Oct 16, 2006 | 04:05 PM
Finest's Avatar
Default Re: (Arturbo)
WHOA! Lucky day for you guys! That car is pretty badass, it would have been a shame to see it go down for that!
We all fu.ck up from time to time. I bet you will never ever put wheels on without first checking if they're on correct anymore!
But what I'm confused on is what lug pattern size are those? Is it a universal 100/114.5x4 wheel? Even on 114.5x4 wheel, you can't even seat it on a 100x4 hub? How in the hell did you manage to put the wheels on in the first place?
Old Oct 16, 2006 | 04:10 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I would have fired you if you would have done that to me. </TD></TR></TABLE>
me too...damn man thats insane!!!
Old Oct 16, 2006 | 04:13 PM
josh green's Avatar
ART- We are friends, this isnt business.
Finest- the wheels just slipped on like normal, I didnt force them on or anything. I think they are just holes there to make the wheels lighter.
I am not an idiot and this is the first time i have ever done anything like it. Hell I am usually the one double checking the car.
Old Oct 16, 2006 | 04:19 PM
B18 CYA's Avatar
so what were his times?
Old Oct 16, 2006 | 04:33 PM
Finest's Avatar
Default Re: (josh green)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh green &raquo;</TD></TR><TR><TD CLASS="quote">Finest- the wheels just slipped on like normal, I didnt force them on or anything. I think they are just holes there to make the wheels lighter.
Any pictures with the wheel off? What kind of damage did it do? (besides what you listed earlier)
Old Oct 16, 2006 | 04:36 PM
josh green's Avatar
I think he went like 11.5x @ 130 or something like that. He ran on low boost (20psi). He said "glad I didnt put it in high boost" speaking of the brakes.
This will be something that I will NEVER do again.
And being the good friend I am, I am paying for everything.
We have yet to pull anything apart. We will do that when the parts come in. For now it is still sitting on the trailer.
Old Oct 16, 2006 | 04:48 PM
sittin on GOLD's Avatar
that has happend to me before on my coupe turbo as well. on skunkworks studds though, and yes it was spot welded welded on each stud. but hasn't happened on me since i switched over to arp studds.
Old Oct 16, 2006 | 05:08 PM
josh green's Avatar
the studs are skunk2 that are installed properly, pressed apart, new bearings, pressed in, welded.
Old Oct 16, 2006 | 05:14 PM
damn yea same with mine...but still happend to me too... i was suprised and i wasn't making nearly as much power as u, but mine happend like back in 99-00 or someting like that.
Old Oct 16, 2006 | 05:18 PM
josh green's Avatar
my guess would be it happened during the burnout, that twin disk hits pretty hard.
Old Oct 16, 2006 | 07:30 PM
mrbsponge's Avatar
this lug nut issue seemed to happen to me with my Lensos ONLY, with my bogarts they are fine, but if i run the lensos i have major issues, and i use the proper lug nut pitch angle for them as well
Old Oct 17, 2006 | 04:45 AM
SPOOLINmatt's Avatar
Default Re: (mrbsponge)
i ran them on my last car with 600hp. i never had a single issue. the other side is just fine. Freak things. Its crazy that my front left caliper decided to blow out at the end of the track too.
Old Oct 17, 2006 | 11:05 AM
ATYPR's Avatar
Default Re: (SPOOLINmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">i ran them on my last car with 600hp. i never had a single issue. the other side is just fine. Freak things. Its crazy that my front left caliper decided to blow out at the end of the track too. </TD></TR></TABLE>
Just god smiling down on you. If it didn't happen you guys never would have looked at the wheels and you may have gotten killed on the next run.
glad you are OK
Old Oct 17, 2006 | 11:26 AM
gsrious's Avatar
your friend is here and so are you. learn from this mistake and go build an even faster, more badass car.
^^as stated above, god is just smile down on you.
*btw, what kind of rims are those... the blacks ones that you guys have? they look really nice.
Old Oct 17, 2006 | 02:17 PM
Default Re: (gsrious)
lensos painted.
Old Oct 17, 2006 | 08:12 PM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt &raquo;</TD></TR><TR><TD CLASS="quote">lensos painted. </TD></TR></TABLE>
are you sure... im thinking that myself. although, the spokes seem to curve differently.
Old Oct 18, 2006 | 06:08 PM
mportracer33's Avatar
why did he lose the brakes??? how would the brakes go out?
Old Oct 18, 2006 | 06:22 PM
Default Re: (mportracer33)
front let caliper, something apparently busted inside it. crazy stuff. Havnt messed with it yet. this weekend maybe.
Old Oct 19, 2006 | 06:39 AM
EvoB23's Avatar
We all get lucky here or there. The good thing is your friends is still with us.
Old Oct 19, 2006 | 08:01 AM
HybridKOOP's Avatar
Default Re: (EvoB23)
I am confused.
You mounted the wheel w/ holes in the wheels that were not made for the studs to go through... I understand that part.
But, what does that have to do with the left caliper blowing up and your buddy losing his brakes? I could see the car having extreme vibration or at the worst a wheel breaking under hard braking or acceleration, but I am not tieing the wheel mounting problem and the caliper problem together.
What am I missing that everyone else is getting? Haha...
Old Oct 19, 2006 | 08:33 AM
josh green's Avatar
Default Re: (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">I am confused.
What am I missing that everyone else is getting? Haha...</TD></TR></TABLE>
Me mounting the wheel improperly has nothing to do with the brakes going out, that is a totally different side of the car. I was just stating that while his wheel COULD have come off down the track his caliper failed on the opposite side of the imporoperly mounted wheel.
This car is going to need a parachute, and its **** like that that makes it all the more reason.
Old Oct 19, 2006 | 08:35 AM
josh green's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure... im thinking that myself. although, the spokes seem to curve differently.</TD></TR></TABLE>
I think its the wide angle lens throwing you off.
