relocationg the map sensor to the throttle body?
i used the search and can't seem to find the material. just got a 70 ml throttle body and have to relocate the map sensor. any help or insight would be great
thanks
pooper
thanks
pooper
install o-ring into the groove on the tb. install map sensor, bolt down with 2 screws. might have to extend the wiring. extending wiring means pull the harness off the firewall and plug it in.
if there's threads for the map sensor port you could get a brass nipple and thread it into the tb and continue using a firewall mounted map.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">
if there's threads for the map sensor port you could get a brass nipple and thread it into the tb and continue using a firewall mounted map.</TD></TR></TABLE>
I did a similar method i used a plastic nipple
and honda bonded it in the hole then ran a hose to the map, has not leaked in 5 yrs
PearlBlueType-S
Jan 21, 2006 10:35 PM
