Timing belt in h22a1 loose
Old Oct 16, 2006 | 11:22 AM
batlground1's Avatar
Default Timing belt in h22a1 loose
customer states that timing belt is loose. checked and it is...but the auto tensioner is for the balance shaft and the adjustment nut is for the timing balance belt. customer has all new belts installed.....i need to know how to tighten the timing belt itself.
Old Oct 16, 2006 | 12:57 PM
Dangger's Avatar
Default Re: Timing belt in h22a1 loose (batlground1)
recently done an h23a1 the timing belt tensioner is behind the balance belt tensioner
Old Oct 16, 2006 | 02:20 PM
Revi's Avatar
is this a 4th or 5th gen prelude? If its a 5th gen the timming belt is adjusted automatically. If the timming belt is loose its a bad auto tensioner. The bolt you are refering to tightens the balancer shaft belt, assuming this is a 5th gen.
Old Oct 16, 2006 | 02:21 PM
Revi's Avatar
Default Re: Timing belt in h22a1 loose (Revi-Ra)
whoops, didnt see the H22a1. It has an auto tensioner. There is not way to adjust the belt like a h23.
RobTurbo
Honda CR-V & Element
Apr 21, 2018 03:59 PM
yankie_1132
Apr 17, 2012 03:33 AM
rasta420
Dec 21, 2008 09:52 PM
JDMtype Eg6
Feb 18, 2007 05:45 AM
smkngsr
May 8, 2002 02:49 PM
