obd 1 or 2
If im running a obd 1 block with an obd 2 head, would i want the obd 1 or 2 for the ecu.
And how can I tell what im getting, or does it not really matter,
as long as its wired for obd 1 it will work just fine?
First b-series swap, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">dont quote me on this but i believe you can use an obd2 dizzy on an obd1 setup...im sure someone else can clarify...</TD></TR></TABLE>
yes
yes
can you do it the other way around?
and is there any way you can run obd1 and hook up an obd 2 plug,
so you can use the obd2 reader? or would i just be better of sticking
to obd1 since there is so many chipping and modding advantages?
and also instead of running 2 o2 sensors can you just splice the wires
and make the computer think I have two while only running one.
jdmvtecej2
Apr 2, 2008 10:41 AM
