Automatic Transmission Problem!!!
Old May 3, 2002 | 11:21 PM
tFUnK's Avatar
Default Automatic Transmission Problem!!!
Today I noticed that after I park, I have difficulty shifting into PARK. Today is the first time it has ever happend to me. It would get stuck at R (right before P) when I shift from D to P. It feels like how it would feel when the push button isn't pressed, except I made sure that the button was pressed fully when I shifted. I pulled back to D and then jammed it forward to P and it shifted with the extra force. I know this is not normal, but I haven't done anything to mess up my tranny (I only downshift, but always let off the throttle before anyway, plus I don't think downshifting grinds gears). I'm thinking that the mechanism/sensor thing is out of whack. On automatics you can't shift to or from P without stepping on the brake pedal. If you try to shift without stepping on the brake, it wont allow you to push the button down when shifting from P, or it just wont let you shift into P. Well, thats what it feels like; it wont shift into P even when my brake is on. Can anyone give some advice? Thanks, I'm probably taking it to Honda this coming week.
Old May 4, 2002 | 12:23 AM
Tetsuwan Atomu's Avatar
Default Re: Automatic Transmission Problem!!! (tFUnK)
take it to the shop....sorry I am not that much of a help, but I heard this problem before...I think you have to use your key to release some thing, so you could shift w/o using brake.the release thing is near your tranny shifter. it has little key hole....that's all I could help...FUQ me
Old May 4, 2002 | 12:39 AM
tFUnK's Avatar
Default Re: Automatic Transmission Problem!!! (xshh3x)
i'll look for it thanks! i think i might know what your talking about
Old May 4, 2002 | 01:14 AM
Ham'ed Hatch
Guest
Posts: n/a
you may need to adjust the shifter cable under the console. sounds like that's the problem. just probably needs aligned. it explains how to do so in a chiltons/helms/whatever.
hth
Old May 4, 2002 | 01:28 AM
tFUnK's Avatar
Default Re: Automatic Transmission Problem!!! (HoMoCo FoLife)
i was actualy just looking through a helms for a 84-90 civic... the task might be a little too much for a newbie like myself, but once the helms stop intimidating me, i'll check to see what's going on, thanks
Old May 4, 2002 | 06:18 AM
JaeOne3345's Avatar
automatic transmission problem
lol jk..not sure..your best bet is to take it to an auto tranny specialist
bumble78
Jul 17, 2015 07:38 AM
Kane666
Jan 28, 2013 04:50 AM
kittycars
Honda CR-V & Element
Oct 16, 2011 11:05 AM
ludesrv
Oct 10, 2007 11:43 AM
